주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Quantum Axis A23 Battery Replacement
필요한 것
  1. Quantum Axis A23 Battery Replacement, Removing the Case: 1 단계, 이미지 1개 중 1개
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
    댓글 쓰기
  2. Quantum Axis A23 Battery Replacement, Removing the Tape: 2 단계, 이미지 1개 중 1개
    • Once the device is open, remove the tape from the the battery.
    댓글 쓰기
  3. Quantum Axis A23 Battery Replacement, Prying the Battery Off the Screen: 3 단계, 이미지 1개 중 1개
    • Carefully pry up the battery by wedging the plastic opening tool under the battery. It is glued to the screen so it will be a delicate removal process.
    댓글 쓰기
  4. Quantum Axis A23 Battery Replacement, Removing the Battery: 4 단계, 이미지 1개 중 1개
    • Remove all tape connected to the battery.
    댓글 쓰기
  5. Quantum Axis A23 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Once the battery is removed, take wire cutters to the two wires attaching the battery to the motherboard and cut the red and black wires in the middle. Then, strip the both the red and black wires halfway with the wire stripper/cutter tool.
    • It's important to cut the wires in the middle to ensure an easy replacement. Also, be careful when stripping the wires because they are delicate and likely to break apart.
    • When cutting the wires, CUT THEM ONE AT A TIME to avoid shorting the battery.
    댓글 쓰기
  6. Quantum Axis A23 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Take the new battery and strip both the red and black wires in the middle with wire stripper/cutter tool.
    • Take the red wire from the battery and the red wire from your device's motherboard and twist the two ends together then wrap in electrical tape. Repeat this step for the black wires.
    댓글 쓰기
결론
Tape the battery back onto the back of the device's screen and snap the rear case back on to finish this repair.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Nicole
회원 가입일: 01/12/15
407 평판
안내서 4개를 작성함
USF Tampa, Team 1-5, Tanski Winter 2015 USF Tampa, Team 1-5, Tanski Winter 2015 회원
USFT-TANSKI-W15S1G5
3 회원들
안내서 10개를 작성함
1가이드 댓글
Were can i purchase the battery?
Nisha Niles - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 35
전체 시간: 864
