주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Quick Antenna Connection Check for Delphi MyFi XM2GO
필요한 것
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: 1 단계, 이미지 3개 중 1개 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: 1 단계, 이미지 3개 중 2개 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: 1 단계, 이미지 3개 중 3개
      • Locate the large button on the top of the device.
      • Push down on the button and slide the cover away from the button.
      • The battery removal tab may pop up.
      댓글 쓰기
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: 2 단계, 이미지 3개 중 1개 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: 2 단계, 이미지 3개 중 2개 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: 2 단계, 이미지 3개 중 3개
      • Grab the red pull tab and pull down to unlock the latch.
      • Pull the battery out.
      댓글 쓰기
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Quick Antenna Connection Check for Delphi MyFi XM2GO: 3 단계, 이미지 1개 중 1개
      • Under the battery is a magnetic mat, shown in red, that shields battery interference with the reception of the XM Satellite antenna.
      • This mat is stuck to the back of the device like a sticker and can be removed.
      • CAUTION: Do not operate the device without this magnetic shield.
      댓글 쓰기
    2. Quick Antenna Connection Check for Delphi MyFi XM2GO: 4 단계, 이미지 3개 중 1개 Quick Antenna Connection Check for Delphi MyFi XM2GO: 4 단계, 이미지 3개 중 2개 Quick Antenna Connection Check for Delphi MyFi XM2GO: 4 단계, 이미지 3개 중 3개
      • On the bottom left side of the magnetic mat, the corner can be lifted up to reveal the U.FL antenna connector. A spudger or your fingernails can be used to pry up the corners.
      • These U.FL antenna connections are standard for most portable devices and WiFi cards. They may become detached through use and may be checked if no reception is present.
      • Lift up the corner and notice the two connectors going to the PCB.
      댓글 쓰기
    3. Quick Antenna Connection Check for Delphi MyFi XM2GO: 5 단계, 이미지 2개 중 1개 Quick Antenna Connection Check for Delphi MyFi XM2GO: 5 단계, 이미지 2개 중 2개
      • Both of these connectors must be firmly attached to the PCB. Try pressing them firmly to make sure they are making full contact.
      댓글 쓰기
    4. Quick Antenna Connection Check for Delphi MyFi XM2GO: 6 단계, 이미지 3개 중 1개 Quick Antenna Connection Check for Delphi MyFi XM2GO: 6 단계, 이미지 3개 중 2개 Quick Antenna Connection Check for Delphi MyFi XM2GO: 6 단계, 이미지 3개 중 3개
      • On the top right corner, the magnetic mat can be lifted up to check another U.FL connector as with the 3rd step.
      • This mat can be pressed down again to secure after checking the connector.
      댓글 쓰기
    5. Quick Antenna Connection Check for Delphi MyFi XM2GO: 7 단계, 이미지 1개 중 1개
      • Try pressing down on the U.FL connector, as seen in this picture, to ensure a secure connection.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Scott Byer
회원 가입일: 03/09/12
88 평판
안내서 5개를 작성함
Clemson, Team 1-2, Benson Spring 2012 Clemson, Team 1-2, Benson Spring 2012 회원
CLEM-BENSON-S12S1G2
3 회원들
안내서 45개를 작성함
1가이드 댓글
la radio sigue sin funcionar
luis - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 32
전체 시간: 3,464
