주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RAM memory replacement for why! W253EU
필요한 것
    1. RAM memory replacement for why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 1개 RAM memory replacement for why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 2개 RAM memory replacement for why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 3개
      • Turn off the computer.
      • Before each operation it is important to start with the removal of the accumulator.
      • Take the slide unlocked into position, remove the battery.
      댓글 쓰기
    1. RAM memory replacement for why! W253EU, Access to RAM and CPU from why! W253EU: 2 단계, 이미지 2개 중 1개 RAM memory replacement for why! W253EU, Access to RAM and CPU from why! W253EU: 2 단계, 이미지 2개 중 2개
      • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
      댓글 쓰기
    2. RAM memory replacement for why! W253EU: 3 단계, 이미지 3개 중 1개 RAM memory replacement for why! W253EU: 3 단계, 이미지 3개 중 2개 RAM memory replacement for why! W253EU: 3 단계, 이미지 3개 중 3개
      • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
      • Now lift the cover carefully.
      • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
      댓글 쓰기
    3. RAM memory replacement for why! W253EU: 4 단계, 이미지 1개 중 1개
      • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
      댓글 쓰기
    1. RAM memory replacement for why! W253EU, RAM memory: 5 단계, 이미지 3개 중 1개 RAM memory replacement for why! W253EU, RAM memory: 5 단계, 이미지 3개 중 2개 RAM memory replacement for why! W253EU, RAM memory: 5 단계, 이미지 3개 중 3개
      • Locate the two memory modules.
      • Release the locking spring on both sides of the module.
      • Now lift the module with its connector slightly.
      댓글 쓰기
    2. RAM memory replacement for why! W253EU: 6 단계, 이미지 1개 중 1개
      • Now remove the module from its connector by pulling it out symmetrically to its axis.
      • If necessary, repeat the procedure from the previous step with the second module.
      • Attention: the two memory modules must be identical, mainly in terms of their memory capacity!
      댓글 쓰기
결론
To reassemble, follow the instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
33,634 평판
안내서 283개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 38
전체 시간: 633
