주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RAM memory upgrade / replacement
필요한 것
    1. RAM memory upgrade / replacement, Remove the battery: 1 단계, 이미지 3개 중 1개 RAM memory upgrade / replacement, Remove the battery: 1 단계, 이미지 3개 중 2개 RAM memory upgrade / replacement, Remove the battery: 1 단계, 이미지 3개 중 3개
      • Turn the laptop upside down and gently lay it down on a flat surface.
      • Slide the battery release latch to the right and the battery will pop up slightly.
      • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
      • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
      댓글 쓰기
    1. RAM memory upgrade / replacement, Remove the captive screw of the service door: 2 단계, 이미지 1개 중 1개
      • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
      댓글 쓰기
    2. RAM memory upgrade / replacement, Remove the service door: 3 단계, 이미지 3개 중 1개 RAM memory upgrade / replacement, Remove the service door: 3 단계, 이미지 3개 중 2개 RAM memory upgrade / replacement, Remove the service door: 3 단계, 이미지 3개 중 3개
      • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
      • Continue along the short edges.
      • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
      댓글 쓰기
    3. RAM memory upgrade / replacement, Identify the components: 4 단계, 이미지 1개 중 1개
      • RAM memory modules
      • HDD (Hard Disk Drive)
      • mSATA SSD slot
      • Wifi & BT module (Wireless card)
      댓글 쓰기
    1. RAM memory upgrade / replacement, Offset the protective flap's boomerang-like effect: 5 단계, 이미지 1개 중 1개
      • Without bending it, gently turn the RAM modules' protective flap to the left and stick it to the base enclosure with a piece of adhesive tape.
      댓글 쓰기
    2. RAM memory upgrade / replacement, Dismount the top memory module: 6 단계, 이미지 3개 중 1개 RAM memory upgrade / replacement, Dismount the top memory module: 6 단계, 이미지 3개 중 2개 RAM memory upgrade / replacement, Dismount the top memory module: 6 단계, 이미지 3개 중 3개
      • Take the spudger and place it over the bottom retaining arm so that the former can have a good grip on the latter. When you feel the grip, straightly towards yourself and quite forcefully, push the retaining arm off. You are going to hear a tiny click when the arm will be detached.
      • Repeat the last operation on the top retaining arm. This time pushing it off towards the opposite direction: as soon as you released the second arm also, the memory module will tilt up immediately.
      • The top memory module is now released, and, if you're grounded, you can take it out of its slot. Grab the module as it is shown in pic#3 and - maintaining its inclination and making it lightly and repeatedly swing as a pendulum (btw left and right, as the bent blue arrow tries to show) - pull it out and put it away.
      댓글 쓰기
    3. RAM memory upgrade / replacement, Dismount the bottom memory module: 7 단계, 이미지 1개 중 1개
      • Repeat the same process on the bottom memory module in order to remove that one too.
      댓글 쓰기
    4. RAM memory upgrade / replacement, Mount one of the new modules inside the bottom slot: 8 단계, 이미지 3개 중 1개 RAM memory upgrade / replacement, Mount one of the new modules inside the bottom slot: 8 단계, 이미지 3개 중 2개 RAM memory upgrade / replacement, Mount one of the new modules inside the bottom slot: 8 단계, 이미지 3개 중 3개
      • Are you grounded? If yes, take one of the new memory modules and align it with the connector by the correct side: the close-to-the-middle indentation of the module has to face the highlighted pin.
      • Then, keeping it tilted and carrying on the "pendulum" movement, gently push the module inside the slot. STOP when you feel you can't go any further: the new memory module should be now tilted and totally inside the connector - as it is shown in pic#2 - and the indentation of the module should almost be attached to the centring pin.
      • Once that the module is so positioned, gently press it down pushing it in the middle with your fingers until you hear a loud click: that sound means that the retaining arms have correctly grabbed the module and that the latter one has been successfully inserted!
      댓글 쓰기
    5. RAM memory upgrade / replacement, Mount the second module on top of the previous one: 9 단계, 이미지 3개 중 1개 RAM memory upgrade / replacement, Mount the second module on top of the previous one: 9 단계, 이미지 3개 중 2개 RAM memory upgrade / replacement, Mount the second module on top of the previous one: 9 단계, 이미지 3개 중 3개
      • Repeat the same process in order to insert the remaining module and it's done!
      댓글 쓰기
결론
You have successfully replaced the RAM memory! Congratulations :) Now remove the tape and reassemble the service door and the battery. Enjoy the new piece of hardware, cheers!
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Roberto Bartolacci
회원 가입일: 02/10/18
1,548 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 77
전체 시간: 3,616
