주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA 8 Apollo Screen Replacement
필요한 것
    1. RCA 8 Apollo Screen Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your tablet before beginning to disassemble.
      댓글 쓰기
    2. RCA 8 Apollo Screen Replacement: 2 단계, 이미지 2개 중 1개 RCA 8 Apollo Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Insert an iFixit opening tool into the gap between the tablet and back panel.
      • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
      • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
      댓글 쓰기
    3. RCA 8 Apollo Screen Replacement: 3 단계, 이미지 2개 중 1개 RCA 8 Apollo Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Disconnect the red and black speaker wires from the tablet.
      • The front and back of the tablet will be disconnected.
      댓글 쓰기
    1. RCA 8 Apollo Screen Replacement, Display Assembly: 4 단계, 이미지 3개 중 1개 RCA 8 Apollo Screen Replacement, Display Assembly: 4 단계, 이미지 3개 중 2개 RCA 8 Apollo Screen Replacement, Display Assembly: 4 단계, 이미지 3개 중 3개
      • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
      • Remove the yellow tape that is around the battery.
      • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
      • If the connector is misaligned, the pins can bend, causing permanent damage.
      댓글 쓰기
    2. RCA 8 Apollo Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the three screws from the motherboard using a Phillips screwdriver.
      댓글 쓰기
    3. RCA 8 Apollo Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the battery and motherboard together from the tablet.
      • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
      • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
      댓글 쓰기
    1. RCA 8 Apollo Screen Replacement, Screen: 7 단계, 이미지 3개 중 1개 RCA 8 Apollo Screen Replacement, Screen: 7 단계, 이미지 3개 중 2개 RCA 8 Apollo Screen Replacement, Screen: 7 단계, 이미지 3개 중 3개
      • Remove the screw from the bottom left of the tablet.
      • Place an opening tool under the screen.
      • Pry up the screen and it will unclip from the clips holding the screen down.
      • Avoid using too much force to prevent the glass from breaking.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
McKenna Shipper
회원 가입일: 04/12/24
123 평판
안내서 1개를 작성함
Casper College, Team 1-1, Lareau Spring 2024 Casper College, Team 1-1, Lareau Spring 2024 회원
CASC-LAREAU-S24S1G1
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 26
전체 시간: 264
