주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA CC310 Effect Button Circuit Board Replacement
필요한 것
    1. RCA CC310 Effect Button Circuit Board Replacement, Disassembling RCA CC310 Left Cover: 1 단계, 이미지 2개 중 1개 RCA CC310 Effect Button Circuit Board Replacement, Disassembling RCA CC310 Left Cover: 1 단계, 이미지 2개 중 2개
      • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
      • Remove the one 3.8mm Phillips #0 screw on the bottom.
      • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
      댓글 쓰기
    2. RCA CC310 Effect Button Circuit Board Replacement: 2 단계, 이미지 2개 중 1개 RCA CC310 Effect Button Circuit Board Replacement: 2 단계, 이미지 2개 중 2개
      • Remove 5.8mm Phillips #1 screw from the side button panel.
      • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
      댓글 쓰기
    3. RCA CC310 Effect Button Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 RCA CC310 Effect Button Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
      • Pry along the seam on the top side near the buttons with a spudger.
      댓글 쓰기
    4. RCA CC310 Effect Button Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 RCA CC310 Effect Button Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
      • Pull the left panel away from the rest of the camcorder.
      • Unplug the red speaker cable located at the rear of the device.
      • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
      댓글 쓰기
    1. RCA CC310 Effect Button Circuit Board Replacement, Effect Button Circuit Board: 5 단계, 이미지 2개 중 1개 RCA CC310 Effect Button Circuit Board Replacement, Effect Button Circuit Board: 5 단계, 이미지 2개 중 2개
      • Unplug the two cables on the bottom of the effect button circuit board.
      • Unplug the cable at the top left side of the motherboard.
      댓글 쓰기
    2. RCA CC310 Effect Button Circuit Board Replacement: 6 단계, 이미지 3개 중 1개 RCA CC310 Effect Button Circuit Board Replacement: 6 단계, 이미지 3개 중 2개 RCA CC310 Effect Button Circuit Board Replacement: 6 단계, 이미지 3개 중 3개
      • Pull the plastic tabs away from the circuit board.
      • Pull the board away from the camcorder.
      • Use a spudger to help push the mini-circuit board away from the camcorder at the same time.
      • Unplug the cable in the middle of the effects board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Oliver Adams
회원 가입일: 01/19/11
629 평판
안내서 6개를 작성함
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G20
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 40
전체 시간: 2,183
