주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA CC310 Viewfinder Replacement
필요한 것
    1. RCA CC310 Viewfinder Replacement, Viewfinder: 1 단계, 이미지 2개 중 1개 RCA CC310 Viewfinder Replacement, Viewfinder: 1 단계, 이미지 2개 중 2개
      • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
      • Pushing the viewfinder assembly to the right makes lifting the flap easier.
      • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
      댓글 쓰기
    2. RCA CC310 Viewfinder Replacement: 2 단계, 이미지 3개 중 1개 RCA CC310 Viewfinder Replacement: 2 단계, 이미지 3개 중 2개 RCA CC310 Viewfinder Replacement: 2 단계, 이미지 3개 중 3개
      • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
      • Lift the plastic where the cable connects off of the viewfinder assembly.
      • Disconnect the cable inside by pulling it apart.
      댓글 쓰기
    3. RCA CC310 Viewfinder Replacement: 3 단계, 이미지 2개 중 1개 RCA CC310 Viewfinder Replacement: 3 단계, 이미지 2개 중 2개
      • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
      • Lift the viewfinder plastic assembly up and remove.
      댓글 쓰기
    4. RCA CC310 Viewfinder Replacement: 4 단계, 이미지 1개 중 1개
      • Flip back the viewfinder access tab.
      • Unscrew the 7.0mm ph #0 screw next to the mirror.
      댓글 쓰기
    5. RCA CC310 Viewfinder Replacement: 5 단계, 이미지 3개 중 1개 RCA CC310 Viewfinder Replacement: 5 단계, 이미지 3개 중 2개 RCA CC310 Viewfinder Replacement: 5 단계, 이미지 3개 중 3개
      • Lift off both sides of the plastic assembly.
      • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
      댓글 쓰기
    6. RCA CC310 Viewfinder Replacement: 6 단계, 이미지 2개 중 1개 RCA CC310 Viewfinder Replacement: 6 단계, 이미지 2개 중 2개
      • Lift the microphone circuit board straight up.
      • Unclip the cable connected to the circuit board.
      댓글 쓰기
    7. RCA CC310 Viewfinder Replacement: 7 단계, 이미지 3개 중 1개 RCA CC310 Viewfinder Replacement: 7 단계, 이미지 3개 중 2개 RCA CC310 Viewfinder Replacement: 7 단계, 이미지 3개 중 3개
      • Lift plastic housing and guide the wires from underneath.
      • Lift out the entire circuit board and viewfinder.
      • Replace entire circuit board and viewfinder assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Oliver Adams
회원 가입일: 01/19/11
629 평판
안내서 6개를 작성함
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G20
4 회원들
안내서 14개를 작성함
1가이드 댓글
do you know where i can find a relacement one of these parts
Connor Byrley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 45
전체 시간: 2,946
