주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA Maven Pro 11 Battery Replacement
필요한 것
    1. RCA Maven Pro 11 Battery Replacement, Cover: 1 단계, 이미지 2개 중 1개 RCA Maven Pro 11 Battery Replacement, Cover: 1 단계, 이미지 2개 중 2개
      • Remove all the 8 mm Phillips head screws on the side and back of the device.
      댓글 쓰기
    2. RCA Maven Pro 11 Battery Replacement: 2 단계, 이미지 2개 중 1개 RCA Maven Pro 11 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Pry off the cover by sticking a wedge in between the screen and the cover.
      • Be careful with the plastic because it can easily break.
      • Once the cover is partly removed, use your hands to take off the rest of the cover.
      댓글 쓰기
    1. RCA Maven Pro 11 Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 RCA Maven Pro 11 Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Pull out the pins circled in the picture.
      • These pins can be removed by hand. Just pull on them individually.
      댓글 쓰기
    2. RCA Maven Pro 11 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Use the opening tools to peel the battery off of the panel.
      • The glue is located in the corners.
      • Do not bend or puncture the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brady Alexander Cristancho
회원 가입일: 03/04/19
424 평판
안내서 4개를 작성함
2가이드 댓글
My husband installed my new battery in my ex's haven pro tablet and when we turned it on it said battery charger 65%. I then turned it back off to co time charging to 100% it when I checked in a few hours, the battery level dropped to 20% and I cannot get it to recharge. It is now completely dead and will not take a charge what should I do?
Carol tyciak - 답글 공유
My husband installed a new battery into my RCA Maven Pro tablet and when we turned it on, it showed 65% battery life. I then turned it off to continue to charge to 100%. When I checked it in about 4 hours, it was down to 20% and now it is depleted completely and I can't get it to recharge. What should I do now?
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 36
전체 시간: 1,981
