주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA RCT6077W2 Camera Replacement
필요한 것
    1. RCA RCT6077W2 Camera Replacement, Backplate: 1 단계, 이미지 2개 중 1개 RCA RCT6077W2 Camera Replacement, Backplate: 1 단계, 이미지 2개 중 2개
      • Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
      댓글 쓰기
    2. RCA RCT6077W2 Camera Replacement: 2 단계, 이미지 2개 중 1개 RCA RCT6077W2 Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
      • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
      • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
      댓글 쓰기
    1. RCA RCT6077W2 Camera Replacement, Camera: 3 단계, 이미지 1개 중 1개
      • The camera is located in the corner of the motherboard, attached by a ribbon cable. Lift up on the black latch that is holding in the ribbon cable and the cable should pop up and out.
      • Do not use force to try to remove the ribbon cable. The latch may not be lifted up completely, and force can break the ribbon cable away from its connector.
      댓글 쓰기
    2. RCA RCT6077W2 Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Once the cable is removed from the motherboard, the entire camera can simply be removed from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Ryan Williams
회원 가입일: 01/27/15
1,157 평판
안내서 4개를 작성함
Pasco Hernando, Team 1-2, Prince Winter 2015 Pasco Hernando, Team 1-2, Prince Winter 2015 회원
PHSC-PRINCE-W15S1G2
6 회원들
안내서 8개를 작성함
1가이드 댓글
Where can I get the replacement parts (camera and flex cable)
tuesday cannon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 1,287
