주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA Visys 25212 Keypad Replacement
필요한 것
    1. RCA Visys 25212 Keypad Replacement, Handset Battery: 1 단계, 이미지 1개 중 1개
      • Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
      댓글 쓰기
    2. RCA Visys 25212 Keypad Replacement: 2 단계, 이미지 2개 중 1개 RCA Visys 25212 Keypad Replacement: 2 단계, 이미지 2개 중 2개
      • To remove the battery, gently pull up on the white connector located on the left side of the phone.
      댓글 쓰기
    1. RCA Visys 25212 Keypad Replacement, Handset: 3 단계, 이미지 1개 중 1개
      • Remove the four screws, located at each of the corners within the back encasing, with a small Phillips head screwdriver.
      댓글 쓰기
    2. RCA Visys 25212 Keypad Replacement: 4 단계, 이미지 2개 중 1개 RCA Visys 25212 Keypad Replacement: 4 단계, 이미지 2개 중 2개
      • Insert a small flathead screwdriver between the face plate and the back of the handset.
      • Gently pry open the handset. You may need to insert the flathead screwdiver at multiple points in order to open the handset.
      댓글 쓰기
    3. RCA Visys 25212 Keypad Replacement: 5 단계, 이미지 1개 중 1개
      • Using a small Phillips head screwdriver, remove the single screw (located at the top right) holding the circuit board in place.
      댓글 쓰기
    4. RCA Visys 25212 Keypad Replacement: 6 단계, 이미지 2개 중 1개 RCA Visys 25212 Keypad Replacement: 6 단계, 이미지 2개 중 2개
      • Lift up the circuit board to expose the keypad.
      • Be careful not to disconnect the two wires that connect the speaker to the circuit board.
      • Also, notice the two wires located at the bottom when lifting the circuit board, as these are apart of the charger.
      댓글 쓰기
    1. RCA Visys 25212 Keypad Replacement, Keypad: 7 단계, 이미지 1개 중 1개
      • Gently lift out the keypad.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Sandy South
회원 가입일: 01/26/15
431 평판
안내서 4개를 작성함
Pasco Hernando, Team 5-3, Prince Winter 2015 Pasco Hernando, Team 5-3, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G3
6 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 351
