주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
REL T5 Repaste transistors
    1. REL T5 Repaste transistors, Repaste heatsink and pads: 1 단계, 이미지 3개 중 1개 REL T5 Repaste transistors, Repaste heatsink and pads: 1 단계, 이미지 3개 중 2개 REL T5 Repaste transistors, Repaste heatsink and pads: 1 단계, 이미지 3개 중 3개
      • Re-apply thermal grease. Make sure to use an appropriate type. Hint: CPU paste is usually not the best solution.
      • Apply a little dot on the pad and place on the heatsink.
      • After speading it with a spatula, stick two together, and slide to distribute evenly.
      • Careful as to not damage the pads!
      댓글 쓰기
    2. REL T5 Repaste transistors: 2 단계, 이미지 1개 중 1개
      • Apply a thin layer using the spatula on the transistors as well.
      • Mount the amplifier board back on its place.
      • Carefully set the transistors using the screws.
      • Fix the power board using its screws.
      • Check that there are no shorts between the transistors and the heatsink or backplate.
      • TODO image of mounted board
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
Jasper van Zuijlen
회원 가입일: 04/21/25
1,044 평판
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 11
전체 시간: 11
