주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RYOBI P422 Wheel Guard Replacement
    1. RYOBI P422 Wheel Guard Replacement, Battery and Handle: 1 단계, 이미지 2개 중 1개 RYOBI P422 Wheel Guard Replacement, Battery and Handle: 1 단계, 이미지 2개 중 2개
      • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
      • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
      댓글 쓰기
    1. RYOBI P422 Wheel Guard Replacement, Wheel Guard: 2 단계, 이미지 3개 중 1개 RYOBI P422 Wheel Guard Replacement, Wheel Guard: 2 단계, 이미지 3개 중 2개 RYOBI P422 Wheel Guard Replacement, Wheel Guard: 2 단계, 이미지 3개 중 3개
      • Do not perform this task immediately after using the grinder for grinding/cutting. The blade will be to hot to touch and could result in injury.
      • Fully press the spindle lock button.
      • With the spindle lock button held down, use the wrench provided to loosen the clamp nut. Once loose, you can use your fingers to unscrew the nut completely
      댓글 쓰기
    2. RYOBI P422 Wheel Guard Replacement: 3 단계, 이미지 2개 중 1개 RYOBI P422 Wheel Guard Replacement: 3 단계, 이미지 2개 중 2개
      • Remove your grinding/cutting tool by simply pulling it off the spindle.
      • Next remove the disc flange (a.k.a spacer) by pulling it off of the back end of the spindle.
      • The disc flange has two small raised edges on its back side. These ridges need to be aligned with the two flat faces at the back of the spindle lock when reassembled. This will ensure a safe, snug fit for your grinding blades.
      댓글 쓰기
    3. RYOBI P422 Wheel Guard Replacement: 4 단계, 이미지 3개 중 1개 RYOBI P422 Wheel Guard Replacement: 4 단계, 이미지 3개 중 2개 RYOBI P422 Wheel Guard Replacement: 4 단계, 이미지 3개 중 3개
      • Lift the clasp on the grinder guard. Make sure the clasp is completely loosened before proceeding.
      • Rotate the grinder guard so that the three notches on its interior align with the three slots on the grinding head assembly.
      • Once aligned, simply pull the guard off.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
John Lamanuzzi
회원 가입일: 03/20/15
229 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-6, Duarte Spring 2015 UMass Dartmouth, Team 3-6, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G6
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 67
전체 시간: 4,361
