주요 콘텐츠로 건너뛰기
Razer BlackShark V2 Microphone Jack Replacement
필요한 것
  1. Razer BlackShark V2 Microphone Jack Replacement, Ear Cushion: 1 단계, 이미지 1개 중 1개
    • Place the headset so that the left side is facing you.
    • The left side of the headset has the cable attachment and the volume control knob.
  2. Razer BlackShark V2 Microphone Jack Replacement: 2 단계, 이미지 1개 중 1개
    • Scoop your middle and ring finger underneath the top or bottom inner portion of the ear cushion.
    • You should feel a hard plastic ridge.
    • Pull from the hard plastic ridge, being sure not to pull from the soft cushion.
    • Slowly apply pressure to prevent damage.
  3. Razer BlackShark V2 Microphone Jack Replacement: 3 단계, 이미지 1개 중 1개
  4. Razer BlackShark V2 Microphone Jack Replacement: 4 단계, 이미지 2개 중 1개 Razer BlackShark V2 Microphone Jack Replacement: 4 단계, 이미지 2개 중 2개
    • Once the cushion is removed, make sure the hard plastic base with the clips is attached to it.
    • If you are replacing both ear cushions, repeat Steps 1-4 for the other side. Then, insert the new ear cushions by lining up the clips in their respective holes and applying even pressure until they audibly click.
  5. Razer BlackShark V2 Microphone Jack Replacement, Speaker: 5 단계, 이미지 2개 중 1개 Razer BlackShark V2 Microphone Jack Replacement, Speaker: 5 단계, 이미지 2개 중 2개
    • Remove the four screws holding the speaker in the headset using a Phillips #1 screwdriver.
  6. Razer BlackShark V2 Microphone Jack Replacement: 6 단계, 이미지 2개 중 1개 Razer BlackShark V2 Microphone Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Gently grab the headset and slowly apply pressure to the speaker cover; it will come off.
    • Be careful of the wires that are attached to the back of the speaker to ensure they won't be damaged when removing the speaker and its cover.
  7. Razer BlackShark V2 Microphone Jack Replacement: 7 단계, 이미지 3개 중 1개 Razer BlackShark V2 Microphone Jack Replacement: 7 단계, 이미지 3개 중 2개 Razer BlackShark V2 Microphone Jack Replacement: 7 단계, 이미지 3개 중 3개
    • After disconnecting the speaker from the headset, it is still connected by the wires that power the speaker itself.
    • With heat or with a sharp tool, remove the glue around the wires that connect the speaker to the headset.
    • Using the new speaker, you can reattach the wires soldering them in with existing glue.
    • If replacing internal components and NOT the speaker, you can do so without severing any wire connections; operate carefully to not sever them unnecessarily!
  8. Razer BlackShark V2 Microphone Jack Replacement, Microphone Jack: 8 단계, 이미지 2개 중 1개 Razer BlackShark V2 Microphone Jack Replacement, Microphone Jack: 8 단계, 이미지 2개 중 2개
    • Remove the two screws securing the headphone jack using a Phillips #1 screwdriver.
    • These are the same size screws as those that held the speaker in place. Any smaller screws need not be removed.
  9. Razer BlackShark V2 Microphone Jack Replacement: 9 단계, 이미지 1개 중 1개
    • Desolder the microphone jack from the daughterboard.
결론
작성자
3다른 기여자 명과 함께
Jalal Gibson
회원 가입일: 03/08/23
277 평판
안내서 3개를 작성함
1가이드 댓글
Where would be the best place to find a replacement mic jack?
[deleted] - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 38
지난 30일: 142
전체 시간: 3,507
