소개
This guide will walk you through the process of replacing the top housing on your Razer BlackWidow V3 Pro.
필요한 것
Remove the keycaps using either a keycap puller or your hands
Repeat until all keycaps are off
Peel the lower-right rubber feet off just enough to reveal the 9mm Phillips screw.
Lift the top of the keyboard up and slightly to the front.
While pushing up, watch the LED on the front (circled red on the 2nd picture) and make sure it doesn't get damaged while removing the lid.
Flip up the black locking flap on the ZIF connector using a fingernail or a spudger, then carefully pull out the ribbon cable.
