주요 콘텐츠로 건너뛰기
Razer Blade 15" (2019) Heatsink Replacement
필요한 것
  1. Razer Blade 15" (2019) Heatsink Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2019) Heatsink Replacement, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2019) Heatsink Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2019) Heatsink Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 3개
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2019) Heatsink Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2019) Heatsink Replacement, Free the front edge: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Free the front edge: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Free the front edge: 6 단계, 이미지 3개 중 3개
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2019) Heatsink Replacement, Remove the back cover: 7 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Remove the back cover: 7 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Remove the back cover: 7 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2019) Heatsink Replacement, Soften the battery cable tape adhesive: 8 단계, 이미지 2개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Soften the battery cable tape adhesive: 8 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2019) Heatsink Replacement, Peel up the battery cable tape: 9 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Peel up the battery cable tape: 9 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Peel up the battery cable tape: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2019) Heatsink Replacement, Disconnect the battery: 10 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Disconnect the battery: 10 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Disconnect the battery: 10 단계, 이미지 3개 중 3개
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2019) Heatsink Replacement, Remove the screw covers: 11 단계, 이미지 2개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Remove the screw covers: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to peel and remove the six screw covers from the heatsink.
  12. Razer Blade 15" (2019) Heatsink Replacement, Unfasten the heatsink: 12 단계, 이미지 2개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Unfasten the heatsink: 12 단계, 이미지 2개 중 2개
    • Use your Phillips screwdriver to remove the two 4.7 mm screws securing the top left and bottom left edges of the heatsink.
    • Use your Phillips screwdriver to fully loosen the eight captive screws securing the center of the heatsink.
    • These screws aren't designed to come out. However, if one does come out, set it and its spring aside.
    • During reassembly, tighten these screws in an X-pattern to evenly compress the thermal paste.
  13. Razer Blade 15" (2019) Heatsink Replacement, Pry up the heatsink: 13 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Pry up the heatsink: 13 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Pry up the heatsink: 13 단계, 이미지 3개 중 3개
    • Don't pry against the motherboard or any cables.
    • Use the flat end of your spudger to pry up the heatsink until it separates from the motherboard at the following locations:
    • Between the bottom left corner of the left metal plate and the SSD
    • The right edge of the right metal plate
    • The top edge of the right metal plate, above the copper pipes
  14. Razer Blade 15" (2019) Heatsink Replacement, Remove the heatsink: 14 단계, 이미지 3개 중 1개 Razer Blade 15" (2019) Heatsink Replacement, Remove the heatsink: 14 단계, 이미지 3개 중 2개 Razer Blade 15" (2019) Heatsink Replacement, Remove the heatsink: 14 단계, 이미지 3개 중 3개
    • Lift the right edge of the heatsink from the motherboard.
    • Slide the heatsink to the right so the left screw tab slides out from under the screen cable.
    • Remove the heatsink.
    • During reassembly:
    • Inspect the thermal pads for damage. Apply new pads if any tear or deform too much.
    • Follow this guide to clean and reapply thermal paste to the CPU and GPU.
결론
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,932개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 36
지난 30일: 108
전체 시간: 2,804
