주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer DeathAdder Chroma Scroll Wheel Replacement
필요한 것
    1. Razer DeathAdder Chroma Scroll Wheel Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
      • Opening the mouse casing will void any warranty that exists for the mouse.
      • Turn the mouse over so the bottom is facing up.
      댓글 쓰기
    2. Razer DeathAdder Chroma Scroll Wheel Replacement: 2 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement: 2 단계, 이미지 2개 중 2개
      • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
      댓글 쓰기
    3. Razer DeathAdder Chroma Scroll Wheel Replacement: 3 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
      댓글 쓰기
    4. Razer DeathAdder Chroma Scroll Wheel Replacement: 4 단계, 이미지 1개 중 1개
      • Use your fingers to identify the location of the screw under the bottom label.
      댓글 쓰기
    5. Razer DeathAdder Chroma Scroll Wheel Replacement: 5 단계, 이미지 1개 중 1개
      • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
      • Clear the label away from around the screw for easier removal.
      댓글 쓰기
    6. Razer DeathAdder Chroma Scroll Wheel Replacement: 6 단계, 이미지 3개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement: 6 단계, 이미지 3개 중 2개 Razer DeathAdder Chroma Scroll Wheel Replacement: 6 단계, 이미지 3개 중 3개
      • Turn the mouse over so the bottom is facing down.
      • Separate the top casing from the bottom base by pulling the top casing upwards.
      • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
      댓글 쓰기
    7. Razer DeathAdder Chroma Scroll Wheel Replacement: 7 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement: 7 단계, 이미지 2개 중 2개
      • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
      • Pulling too hard could damage the wire connections.
      댓글 쓰기
    1. Razer DeathAdder Chroma Scroll Wheel Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
      • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
      댓글 쓰기
    2. Razer DeathAdder Chroma Scroll Wheel Replacement: 9 단계, 이미지 1개 중 1개
      • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
      댓글 쓰기
    3. Razer DeathAdder Chroma Scroll Wheel Replacement: 10 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement: 10 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
      댓글 쓰기
    4. Razer DeathAdder Chroma Scroll Wheel Replacement: 11 단계, 이미지 1개 중 1개
      • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
      댓글 쓰기
    5. Razer DeathAdder Chroma Scroll Wheel Replacement: 12 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement: 12 단계, 이미지 2개 중 2개
      • Disconnect the ribbon connector between the motherboard and the optical sensor.
      댓글 쓰기
    6. Razer DeathAdder Chroma Scroll Wheel Replacement: 13 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the motherboard by grasping the sides and gently pulling upward.
      댓글 쓰기
    1. Razer DeathAdder Chroma Scroll Wheel Replacement, Scroll Wheel: 14 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma Scroll Wheel Replacement, Scroll Wheel: 14 단계, 이미지 2개 중 2개
      • Remove the scroll wheel from the socket by pulling to the right.
      • Pulling too hard could damage the scroll wheel connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Corrie Tung
회원 가입일: 03/24/17
711 평판
안내서 2개를 작성함
Baylor, Team S5-G2, Williams Spring 2017 Baylor, Team S5-G2, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 89
전체 시간: 21,255
