주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer DeathAdder Chroma USB Cable Replacement
필요한 것
  1. Razer DeathAdder Chroma USB Cable Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
    댓글 쓰기
  2. Razer DeathAdder Chroma USB Cable Replacement: 2 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma USB Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
    댓글 쓰기
  3. Razer DeathAdder Chroma USB Cable Replacement: 3 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma USB Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
    댓글 쓰기
  4. Razer DeathAdder Chroma USB Cable Replacement: 4 단계, 이미지 1개 중 1개
    • Use your fingers to identify the location of the screw under the bottom label.
    댓글 쓰기
  5. Razer DeathAdder Chroma USB Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
    댓글 쓰기
  6. Razer DeathAdder Chroma USB Cable Replacement: 6 단계, 이미지 3개 중 1개 Razer DeathAdder Chroma USB Cable Replacement: 6 단계, 이미지 3개 중 2개 Razer DeathAdder Chroma USB Cable Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
    댓글 쓰기
  7. Razer DeathAdder Chroma USB Cable Replacement: 7 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma USB Cable Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
    댓글 쓰기
  8. Razer DeathAdder Chroma USB Cable Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma USB Cable Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
    댓글 쓰기
  9. Razer DeathAdder Chroma USB Cable Replacement: 9 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
    댓글 쓰기
  10. Razer DeathAdder Chroma USB Cable Replacement: 10 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma USB Cable Replacement: 10 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
    댓글 쓰기
  11. Razer DeathAdder Chroma USB Cable Replacement: 11 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
    댓글 쓰기
  12. Razer DeathAdder Chroma USB Cable Replacement: 12 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma USB Cable Replacement: 12 단계, 이미지 2개 중 2개
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
    댓글 쓰기
  13. Razer DeathAdder Chroma USB Cable Replacement: 13 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma USB Cable Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the motherboard by grasping the sides and gently pulling upward.
    댓글 쓰기
  14. Razer DeathAdder Chroma USB Cable Replacement, USB Cable: 14 단계, 이미지 1개 중 1개
    • Locate the USB cable.
    댓글 쓰기
  15. Razer DeathAdder Chroma USB Cable Replacement: 15 단계, 이미지 2개 중 1개 Razer DeathAdder Chroma USB Cable Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the USB cable by pulling it up and out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Henry Shi
회원 가입일: 03/26/17
236 평판
안내서 1개를 작성함
Baylor, Team S5-G2, Williams Spring 2017 Baylor, Team S5-G2, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G2
3 회원들
안내서 6개를 작성함
5가이드 댓글
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - 답글 공유
Thanks for the advice
João Costa Santos - 답글 공유
Great and easy guide thanx alot, saved me a new mouse :)
jesperkb - 답글 공유
Is there a reliable website where I can get a replacement cable with low delivery time?
Bubbles EXE - 답글 공유
where can i get the cable from?
Mourya Singham - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 50
전체 시간: 15,478
