주요 콘텐츠로 건너뛰기
Razer Naga Epic Chroma Battery Replacement
필요한 것
  1. Razer Naga Epic Chroma Battery Replacement, Razer Naga Epic Chroma Disassembly: 1 단계, 이미지 1/1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Battery Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Battery Replacement: 3 단계, 이미지 1/1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Battery Replacement: 4 단계, 이미지 1/1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Take your nylon spudger to gently pry the battery pack from the device.
    • Remove the foam on the battery shell for your new battery.
  6. Razer Naga Epic Chroma Battery Replacement: 6 단계, 이미지 1/1
    • Unplug the power cord from the circuit board in the mouse.
  7. Razer Naga Epic Chroma Battery Replacement: 7 단계, 이미지 1/1
    • Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
    • Insert the new battery into the battery socket.
    • Place the foam on the surface of the new battery (reference Step 5).
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jordan Morgan
회원 가입일: 01/19/17
895 평판
안내서 6개 작성하였습니다
댓글 13개
Do you have battery for sell?
BcTwenty9 - 답글
You can purchase the battery from Amazon. I used the recommendation from ak48disk below, switching the battery leads: https://www.amazon.com/gp/product/B0767K...
Dan Mergens -
Anyone know where to buy a new battery?
Antony Lynch - 답글
Showing how to remove the old battery but not showing or writing what kind of battery one must have (type, where to buy, …) to replace the old one is somewhat stupid - really stupid!
Gooly - 답글
that battery appears to be very swollen………
Levi Coffey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 24
30일 전: 105
전체 시간: 14,434
