주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer Phone Display Assembly Replacement
필요한 것
  1. Razer Phone Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 1개 Razer Phone Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 2개 Razer Phone Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 3개
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    댓글 쓰기
  2. Razer Phone Display Assembly Replacement: 2 단계, 이미지 2개 중 1개 Razer Phone Display Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
    댓글 쓰기
  3. Razer Phone Display Assembly Replacement: 3 단계, 이미지 3개 중 1개 Razer Phone Display Assembly Replacement: 3 단계, 이미지 3개 중 2개 Razer Phone Display Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
    댓글 쓰기
  4. Razer Phone Display Assembly Replacement: 4 단계, 이미지 2개 중 1개 Razer Phone Display Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
    댓글 쓰기
  5. Razer Phone Display Assembly Replacement: 5 단계, 이미지 3개 중 1개 Razer Phone Display Assembly Replacement: 5 단계, 이미지 3개 중 2개 Razer Phone Display Assembly Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    댓글 쓰기
  6. Razer Phone Display Assembly Replacement: 6 단계, 이미지 2개 중 1개 Razer Phone Display Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sebastian Barragan
회원 가입일: 01/24/19
438 평판
안내서 1개를 작성함
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 회원
CPSU-WHITE-W19S19G6
4 회원들
안내서 15개를 작성함
14가이드 댓글
“Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.”
Any suggestions on what adhesive to use to replace the plastic speaker grills?
Vincent - 답글 공유
Double sided tape.
Lucano - 답글 공유
Sir, where can I order Razer Phone 1 LCD Assembly?
baby_zhent17 - 답글 공유
Search on eBay. Phones are often parted out there.
Lucano - 답글 공유
I almost forgot; when searching, your Razer Phone's model number is RZ35-0215, code name: Cheryl.
Lucano - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 87
전체 시간: 16,868
