주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razor A Wheel Replacement
필요한 것
    1. Razor A Wheel Replacement, Wheel: 1 단계, 이미지 1개 중 1개
      • Flip the scooter upside-down with the handlebars and brake on the ground.
      댓글 쓰기
    2. Razor A Wheel Replacement: 2 단계, 이미지 2개 중 1개 Razor A Wheel Replacement: 2 단계, 이미지 2개 중 2개
      • Grab two 3/16" Allen wrenches. Insert one in each screw on the sides of the wheel. Hold one screw in place while turning the other in a counter-clockwise direction, loosening the screw.
      • Once both screws are removed the wheel should be free and fall out.
      • One of the screws fits inside the other. The inner screw should be 5.6 mm in length. During reassembly, the screws can be put back in on either side.
      • During reassembly, do not over-tighten the screws, as you could strip them. They should be just tight enough to prevent the wheel from wobbling.
      댓글 쓰기
    3. Razor A Wheel Replacement: 3 단계, 이미지 2개 중 1개 Razor A Wheel Replacement: 3 단계, 이미지 2개 중 2개
      • When replacing a wheel, look for a metal sleeve in the center of the bearing that may be out of line. Forcing a screw through a sleeve that is out of line could ruin the wheel.
      • Remove any obstructions inside the bearing of the new wheel, and move the inner sleeve in the bearing with an Allen key so that the screws can slide into the bearing freely.
      • Put the replacement wheel into place in the scooter frame.
      • For extra security, you can add a small amount of threadlocker glue to the the bolt and tighten it just until until it doesn't fall off or lock the wheel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jordyn
회원 가입일: 10/09/12
565 평판
안내서 5개를 작성함
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G13
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 24
지난 30일: 88
전체 시간: 14,277
