주요 콘텐츠로 건너뛰기
Reconnecting the Wiring of a Logitech G430 Headset
필요한 것
  1. Reconnecting the Wiring of a Logitech G430 Headset, Wiring: 1 단계, 이미지 1/1
    • Pull the top-left corner of the foam padding up and to the left, and then pull it away from the frame.
  2. Reconnecting the Wiring of a Logitech G430 Headset: 2 단계, 이미지 1/1
    • Remove five screws using a Phillips #0 screwdriver.
    • Pull the blue panel off of the ear piece.
    • Separate these screws for ease of reassembly, as the second layer are a different size!
  3. Reconnecting the Wiring of a Logitech G430 Headset: 3 단계, 이미지 1/1
    • Flip up the microphone to get to the fifth screw in this layer.
    • Remove five screws using a Phillips #1 screwdriver.
  4. Reconnecting the Wiring of a Logitech G430 Headset: 4 단계, 이미지 1/2 Reconnecting the Wiring of a Logitech G430 Headset: 4 단계, 이미지 2/2
    • Pull apart the casing to open it.
    • Most of the connections will be to the small circuit board against the outside piece.
  5. Reconnecting the Wiring of a Logitech G430 Headset: 5 단계, 이미지 1/3 Reconnecting the Wiring of a Logitech G430 Headset: 5 단계, 이미지 2/3 Reconnecting the Wiring of a Logitech G430 Headset: 5 단계, 이미지 3/3
    • Evaluate the internal connections. There should be 6 wires soldered into the top of the board, and 6 wires soldered into the bottom of the board.
    • See the table in the images for the pin connections list. Pins marked with T are on the top half of the circuit board, and B are on the bottom.
    • The first color of each wire lists the color of the casing grouping the wires together. For the top half, the component the wire is coming from is listed first.
  6. Reconnecting the Wiring of a Logitech G430 Headset: 6 단계, 이미지 1/1
    • Solder any severed connections. I recommend referencing How To Solder and Desolder Connections for how to do this!
    • If necessary, you may have to strip some of the casing to expose enough of the wires to be able to reconnect them. You can get away with using scissors if nothing else, but I recommend using a wire stripper for this purpose, as instructed in Wire Stripping.
    • Solder is a toxic substance, so do not inhale it. Do not eat or drink anything after handling solder until after you have thoroughly washed your hands.
    • The wires will get hot very quickly on contact with the iron, so be quick and careful not to burn yourself.
  7. Reconnecting the Wiring of a Logitech G430 Headset: 7 단계, 이미지 1/1
    • After you have finished soldering all connections, test the headset by plugging it into a computer, and check each speaker and the mic. If it still doesn't work, you may not have soldered it correctly, or there might be another problem in the headset or cable.
  8. Reconnecting the Wiring of a Logitech G430 Headset: 8 단계, 이미지 1/1
    • Place the casing back together, and flip over to get to the screw holes.
  9. Reconnecting the Wiring of a Logitech G430 Headset: 9 단계, 이미지 1/1
    • Insert and tighten the bottom layer of screws using a Phillips #1 screwdriver.
  10. Reconnecting the Wiring of a Logitech G430 Headset: 10 단계, 이미지 1/1
    • Insert and tighten top layer of screws using a #1 Phillips screwdriver.
  11. Reconnecting the Wiring of a Logitech G430 Headset: 11 단계, 이미지 1/1
    • Replace foam padding by sliding the back of the padding over the top of the speakers in a downward motion, then pulling the bottom edges of the pads over the bottom of the speakers.
    • Don't forget to thoroughly wash your hands after putting away the solder!
결론
Your headset should now be in working order and in one piece! Enjoy!
다른 2명이 해당 안내서를 완성하였습니다.
Merddyn Sheeley
회원 가입일: 02/24/21
247 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 95
전체 시간: 3,934
