주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Remove the Screen
필요한 것
  1. Remove the Screen, Remove Screws: 1 단계, 이미지 3개 중 1개 Remove the Screen, Remove Screws: 1 단계, 이미지 3개 중 2개 Remove the Screen, Remove Screws: 1 단계, 이미지 3개 중 3개
    • Remove the screws from the bottom, right, and left side of camera.
    댓글 쓰기
  2. Remove the Screen, Remove back: 2 단계, 이미지 1개 중 1개
    • Remove the back of the camera, this may require force.
    댓글 쓰기
  3. Remove the Screen, Remove Metal Bracket: 3 단계, 이미지 1개 중 1개
    • Unscrew the right metal bracket of the viewing lens
    댓글 쓰기
  4. Remove the Screen, Remove front of camera: 4 단계, 이미지 2개 중 1개 Remove the Screen, Remove front of camera: 4 단계, 이미지 2개 중 2개
    • Hello! Today you are going to be learning how to disassemble the front camera of a Nikon Coolpix 5600. You will need a Nikon Coolpix, Ifixit opening tool and a Phillips Screwdriver #00. The first step is to pull the front of the camera off of the mother board. To do this you must pull at each side of front and back on the camera.
    댓글 쓰기
  5. Remove the Screen: 5 단계, 이미지 2개 중 1개 Remove the Screen: 5 단계, 이미지 2개 중 2개
    • Next, pull the grey circular facet that sits on the bottom outside of the camera off by using blue Ifixit opening tool. It is okay to use force if needed.
    댓글 쓰기
  6. Remove the Screen: 6 단계, 이미지 1개 중 1개
    • Now take your Phillips #00 screwdriver and unscrew the bottom right corner screw. Once the screw is out just place it on the table.
    댓글 쓰기
  7. Remove the Screen: 7 단계, 이미지 1개 중 1개
    • Finally, take the same Phillips screwdriver and unscrew the top right corner screw. Place the top screw on the table as well. Now you have accurately disassembled the front camera of a Nikon Coolpix 5600.
    댓글 쓰기
  8. Remove the Screen, Remove the Screen: 8 단계, 이미지 1개 중 1개
    • Unhinge the outer case of the screen from the back of the camera. The screen should still be hanging by wires.
    댓글 쓰기
  9. Remove the Screen: 9 단계, 이미지 1개 중 1개
    • Remove outer case/rim of screen from the back of the camera. The screen should still be hanging by the red wire and white wire.
    댓글 쓰기
  10. Remove the Screen: 10 단계, 이미지 1개 중 1개
    • Pull out the red wire and white wire attaching the screen to the motherboard.
    댓글 쓰기
  11. Remove the Screen: 11 단계, 이미지 1개 중 1개
    • Flip up black lever holding data cable to motherboard, and remove data cable from motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Melissa
회원 가입일: 02/12/13
246 평판
안내서 2개를 작성함
Ohio State, Team 1-2, Buehl Spring 2013 Ohio State, Team 1-2, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G2
2 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 57
전체 시간: 791
