주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Removing Numerical Keypad
필요한 것
  1. Removing Numerical Keypad, Removing Numerical Keypad: 1 단계, 이미지 1개 중 1개
    • You can do this with most keyboards. I had an older Dell keyboard model L100.
    댓글 쓰기
  2. Removing Numerical Keypad: 2 단계, 이미지 1개 중 1개
    • Turn the keyboard over and you will see 15 screws. Remove them.
    댓글 쓰기
  3. Removing Numerical Keypad: 3 단계, 이미지 1개 중 1개
    • Take the keyboard apart. You will find a white rubber sheet under the top part of the keyboard. Cut off the part for the numerical keypad.
    댓글 쓰기
  4. Removing Numerical Keypad: 4 단계, 이미지 1개 중 1개
    • Fasten the top part of the keyboard and take the hacksaw to it. Cut off the numerical keypad part. Do not use power tools because you may produce toxic fumes and even activate fire alarm.
    댓글 쓰기
  5. Removing Numerical Keypad: 5 단계, 이미지 1개 중 1개
    • On the bottom part of the keyboard, remove the three screws and the metal bar holding the keyboard PCB and fold the plastic sheet so it is out of your way when cutting.
    댓글 쓰기
  6. Removing Numerical Keypad: 6 단계, 이미지 1개 중 1개
    • Now mark the bottom part of the keyboard for another cut.
    댓글 쓰기
  7. Removing Numerical Keypad: 7 단계, 이미지 1개 중 1개
    • Cut the bottom part of the keyboard too. Fold or remove the plastic PCB out of the way when cutting.
    댓글 쓰기
  8. Removing Numerical Keypad: 8 단계, 이미지 1개 중 1개
    • Screw the PCB and the metal bar back on.
    댓글 쓰기
  9. Removing Numerical Keypad: 9 단계, 이미지 1개 중 1개
    • Assemble the rest of the keyboard, and fold the plastic sheet under your keyboard. Do not cut it because it will render the keyboard useless.
    댓글 쓰기
  10. Removing Numerical Keypad: 10 단계, 이미지 1개 중 1개
    • Since you have cut the portion of the keyboard with the supporting leg for tilting, supply it with a new leg. You can use a key from the numerical keypad.
    댓글 쓰기
  11. Removing Numerical Keypad: 11 단계, 이미지 1개 중 1개
    • Tape the key to the keyboad
    댓글 쓰기
  12. Removing Numerical Keypad: 12 단계, 이미지 1개 중 1개
    • Presto, you are proud owner of a very geeky looking keyboard with even a piece of the PCB sticking out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Stanko Vuleta
회원 가입일: 06/16/11
242 평판
안내서 1개를 작성함
9가이드 댓글
this is awful !!
Abdullah Kamran - 답글 공유
This is awesome !!
What kind of saw and sawblade are you using?
Fixer - 답글 공유
Manual hacksaw is probably the best choice. Any power tool is liable to burn the plastic and produce fumes which you don't want to be inhaling.
Stanko Vuleta - 답글 공유
Can i do this to an aluminum extended keyboard usb apple?
appleuserfan - 답글 공유
Judging by the position of the cable, the pcb is placed away from the numerical keypad, so I would guess you should be able to do it.
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 84
전체 시간: 13,640
