주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair Mouse Buttons
필요한 것
    1. Repair Mouse Buttons, Engage Wired Optical Mouse Top and Outer Shell Removal: 1 단계, 이미지 1개 중 1개
      • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
      댓글 쓰기
    2. Repair Mouse Buttons: 2 단계, 이미지 1개 중 1개
      • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
      • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
      댓글 쓰기
    3. Repair Mouse Buttons: 3 단계, 이미지 3개 중 1개 Repair Mouse Buttons: 3 단계, 이미지 3개 중 2개 Repair Mouse Buttons: 3 단계, 이미지 3개 중 3개
      • Grab the top shell of the mouse and lift up to remove.
      댓글 쓰기
    4. Repair Mouse Buttons: 4 단계, 이미지 1개 중 1개
      • The capacitors on this board can release stored electrical energy if touched.
      • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
      댓글 쓰기
    5. Repair Mouse Buttons: 5 단계, 이미지 2개 중 1개 Repair Mouse Buttons: 5 단계, 이미지 2개 중 2개
      • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
      댓글 쓰기
    1. Repair Mouse Buttons, Top Shell: 6 단계, 이미지 1개 중 1개
      • Remove the 5 mm round head screw holding the middle piece to the top piece.
      • The outermost shell will now separate from the middle structure.
      댓글 쓰기
    1. Repair Mouse Buttons, Repair Mouse Buttons: 7 단계, 이미지 2개 중 1개 Repair Mouse Buttons, Repair Mouse Buttons: 7 단계, 이미지 2개 중 2개
      • Take the plastic buttons (the part that your fingers click) and flip them over.
      • On the bottom, there should be little plastic towers. Wearing these down can prevent the buttons from clicking properly.
      댓글 쓰기
    2. Repair Mouse Buttons: 8 단계, 이미지 2개 중 1개 Repair Mouse Buttons: 8 단계, 이미지 2개 중 2개
      • File the bottoms of these towers flat to remove any ridges that prevent proper clicking.
      • Make sure to file down both towers. In this image, one is left un-filed to show the difference.
      • This process can also be used for the other buttons on the mouse. Use other guides to disassemble the mouse until the desired button is accessible, and then perform the same filing technique.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
David
회원 가입일: 01/16/13
1,316 평판
안내서 4개를 작성함
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 회원
CPSU-REGAN-W13S18G36
3 회원들
안내서 30개를 작성함
16가이드 댓글
Thanks, worked like a charm.
Michael Beckman - 답글 공유
i used a software fix and all my double random clicks has gone , mouserepair.com solved my problem for good.
Youns T - 답글 공유
What if my gaming mouse doesnt have screws??
k2snakalle123 - 답글 공유
yep no screws……….so am screwed
Nav Dugal - 답글 공유
Really a great help!
Aman Kashyap - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 42
지난 30일: 224
전체 시간: 128,981
