주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
Repair electronics
      • Seen from below, the handpiece is oval-shaped. Wrap with a cloth, with a pair of pliers, a nutcracker or similar. start where the feet are and put the oval in a circle. At the same time, press the handpiece upside down, ie with the metal shank in front, onto a wooden base, whereby the inner life is expelled.
      댓글 쓰기
    1. Repair electronics, Remove handpiece base: 2 단계, 이미지 1개 중 1개
      • Remove the underside of the handpiece by carefully lifting the tabs at the two farthest vertexes of the oval with a small screwdriver.
      댓글 쓰기
    2. Repair electronics, Remove the rubber pad from the motherboard: 3 단계, 이미지 1개 중 1개
      • Remove the rubber pad from the motherboard
      댓글 쓰기
    3. Repair electronics, Remove plastic cap from metal shaft: 4 단계, 이미지 1개 중 1개
      • Use a puller to remove the plastic cap from the metal shaft to expose the defective rubber boot.
      댓글 쓰기
      • Thoroughly clean all housing parts with water and cloth.
      • Thoroughly clean the electronics and mechanics with isopropyl alcohol and a fine brush.
      • Also completely rid the metal shaft of any residue.
      댓글 쓰기
    4. Repair electronics, Repair electronics: 6 단계, 이미지 1개 중 1개
      • Place the inner workings of the handpiece without housing parts in a container in such a way that the main board points downwards and the battery points upwards.
      • Now fill the container with isopropyl alcohol just enough so that the liquid level reaches the circuit board.
      • Leave to stand for 1-2 hours under supervision, then remove the device from the liquid bath and allow to dry.
      댓글 쓰기
    5. Repair electronics, Replace rubber sleeve: 7 단계, 이미지 1개 중 1개
      • The defective rubber sleeve on the metal shaft must be replaced. A spare part is available for less than € 4 on eBay under the following designation: "Philips electric toothbrush Waterproof sealing parts for HX6730 HX6930 HX9340».
      댓글 쓰기
결론
Repeat the steps in order to reassemble your device.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
94%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Gerd Conzetti
회원 가입일: 11/12/17
319 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 52
전체 시간: 1,809
