주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Alarm Clock Clock Projector
필요한 것
    1. Repairing Alarm Clock Clock Projector, The issue: 1 단계, 이미지 1개 중 1개
      • The Problem: here I should read 12:47
      댓글 쓰기
    2. Repairing Alarm Clock Clock Projector: 2 단계, 이미지 2개 중 1개 Repairing Alarm Clock Clock Projector: 2 단계, 이미지 2개 중 2개
      • After removing the 2 screws on the bottom, carefully open the bottom frame, see location of the plastic snaps snaps
      댓글 쓰기
    3. Repairing Alarm Clock Clock Projector: 3 단계, 이미지 3개 중 1개 Repairing Alarm Clock Clock Projector: 3 단계, 이미지 3개 중 2개 Repairing Alarm Clock Clock Projector: 3 단계, 이미지 3개 중 3개
      • Removes the back panel, taking care of the other plastic snaps
      • The projector and its optics is shown in the blue square
      댓글 쓰기
    4. Repairing Alarm Clock Clock Projector, The optics: 4 단계, 이미지 3개 중 1개 Repairing Alarm Clock Clock Projector, The optics: 4 단계, 이미지 3개 중 2개 Repairing Alarm Clock Clock Projector, The optics: 4 단계, 이미지 3개 중 3개
      • cables are tied together with a simple ribbon, in general the inner construction seems very cheap
      • The Projector is made of three parts:
      • A red LED
      • The display with its controller
      • the lens with focus mechanics
      • All parts are kept by tiny screws that you have to remove
      • Take extra caution when handling the display, the flat cable is very weak and can be damaged by improper handling
      댓글 쓰기
    5. Repairing Alarm Clock Clock Projector: 5 단계, 이미지 3개 중 1개 Repairing Alarm Clock Clock Projector: 5 단계, 이미지 3개 중 2개 Repairing Alarm Clock Clock Projector: 5 단계, 이미지 3개 중 3개
      • Carefully remove display from its supporting frame
      • The issue should be ralated to flat cable connecting display to controller
      댓글 쓰기
    6. Repairing Alarm Clock Clock Projector: 6 단계, 이미지 3개 중 1개 Repairing Alarm Clock Clock Projector: 6 단계, 이미지 3개 중 2개 Repairing Alarm Clock Clock Projector: 6 단계, 이미지 3개 중 3개
      • Verify that moving the flat the display returns to work
      • put a stiffner on controller side and close to the display
      • if everything is working, reassemble the clock by doing the steps in reverse order
      댓글 쓰기
    7. Repairing Alarm Clock Clock Projector: 7 단계, 이미지 1개 중 1개
      • Problem solved.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrea Gangemi
회원 가입일: 04/26/15
172 평판
안내서 1개를 작성함
6가이드 댓글
The clock projection displays only partial numbers.one number is missing. The face on the clock displays perfect. It's just The projection on the wall that's missing a digit
eacoch - 답글 공유
my Peakeep clock keeps the correct time but you can't see the time clearly. It's as if the light is turned off.
serena williams - 답글 공유
Thank you for this post! It was the exact starting point to fix my projection clock which was looking dull and had lost a few segments. While the addition of supporting tape helped for a short period, doing it again in conjunction with Step 6 of the following link (http://www.instructables.com/id/How-to-r...) - Applying heat - to the ribbon contact points was the ticket that restored my projection clock functionality.
Adam - 답글 공유
Hi Adam, glad to helped you
Andrea Gangemi - 답글 공유
The display on my clock is missing parts of a number but project correct time , help ?
mandzb87 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 90
전체 시간: 15,087
