주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Internet Explorer Crashes
    1. Repairing Internet Explorer Crashes, Restore Advanced Application Settings: 1 단계, 이미지 1개 중 1개
      • Restore the advanced application settings including the ActiveX Filtering and dialog Pop-Up box settings. You’ll be prompted to remove the personal configurations as well. Check-up that box in order to successfully restore all the settings.
      • Close all other applications and open Internet Explorer.
      • Click Tools -> Internet Options.
      • Click Reset button after checking-up the “Delete personal settings” checkbox.
      댓글 쓰기
    2. Repairing Internet Explorer Crashes, Filter Malfunctioning Extensions: 2 단계, 이미지 1개 중 1개
      • Filter the malfunctioning extensions. Disable all the extensions which are not functioning properly. The list of all extensions is displayed in a dialog box after performing the steps given below:
      • First show the menu bar by pressing the Alt key of your keyboard.
      • Click Tools -> Manage Add-Ons.
      • Set Show -> All add-ons.
      • Filter unwanted extensions including those not working properly.
      댓글 쓰기
    3. Repairing Internet Explorer Crashes, Check Internet DNS Configs: 3 단계, 이미지 1개 중 1개
      • The Internet DNS Configurations might have been changed. Incorrect DNS configurations are one of the reasons behind this issue.
      • Press the Windows Key and X keys simultaneously, and then select the Command Prompt (Admin).
      • Type below commands one by one and press ENTER at the end of each command: • ipconfig /flushdns • ipconfig /registerdns • ipconfig /release
      • Exit Command Prompt and then reboot your PC.
      댓글 쓰기
      • A Troubleshooter tool automatically detects and repairs the Internet Explorer crashes problem. All you’ve to do is-
      • Download the tool called ZombieSoftFix.
      • Install the program on your PC.
      • Follow the on-screen instructions until your problem is completely fixed.
      댓글 쓰기
    4. Repairing Internet Explorer Crashes, Uninstall & Reinstall it again: 5 단계, 이미지 1개 중 1개
      • Some IE files can be corrupt. Uninstalling and reinstalling the same will fix the issue.
      • Insert the Windows OS disc.
      • Press Windows Key and X simultaneously.
      • Click Programs and Features -> Turn Windows features on or off.
      • Uninstall IE and reinstall it again. A system reboot requires.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
VikasMedhekar
회원 가입일: 12/10/14
962 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 48
전체 시간: 2,719
