주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing PS4 Bluetooth Antenna from Defect or System fell
필요한 것
  1. Repairing PS4  Bluetooth Antenna from Defect or System fell, Remove the Wi-Fi antenna: 1 단계, 이미지 2개 중 1개 Repairing PS4  Bluetooth Antenna from Defect or System fell, Remove the Wi-Fi antenna: 1 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
    댓글 쓰기
  2. Repairing PS4  Bluetooth Antenna from Defect or System fell: 2 단계, 이미지 3개 중 1개 Repairing PS4  Bluetooth Antenna from Defect or System fell: 2 단계, 이미지 3개 중 2개 Repairing PS4  Bluetooth Antenna from Defect or System fell: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
    댓글 쓰기
  3. Repairing PS4  Bluetooth Antenna from Defect or System fell: 3 단계, 이미지 3개 중 1개 Repairing PS4  Bluetooth Antenna from Defect or System fell: 3 단계, 이미지 3개 중 2개 Repairing PS4  Bluetooth Antenna from Defect or System fell: 3 단계, 이미지 3개 중 3개
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
    댓글 쓰기
  4. Repairing PS4  Bluetooth Antenna from Defect or System fell: 4 단계, 이미지 2개 중 1개 Repairing PS4  Bluetooth Antenna from Defect or System fell: 4 단계, 이미지 2개 중 2개
    • Remove the 9.7 mm Torx security screw securing the antenna.
    댓글 쓰기
  5. Repairing PS4  Bluetooth Antenna from Defect or System fell: 5 단계, 이미지 2개 중 1개 Repairing PS4  Bluetooth Antenna from Defect or System fell: 5 단계, 이미지 2개 중 2개
    • Remove the Wi-Fi antenna.
    댓글 쓰기
  6. Repairing PS4  Bluetooth Antenna from Defect or System fell, What is Wrong?: 6 단계, 이미지 1개 중 1개
    • As you can see there are 2 solder points . the wire must run through the first point to the second point. But when the system fell it broke that connection and Antenna got bent. If at factory the solder points were not correct it will cause the same lag issue with controller and WiFi.
    댓글 쓰기
  7. Repairing PS4  Bluetooth Antenna from Defect or System fell, Solder it back: 7 단계, 이미지 1개 중 1개
    • This is the easy part. Remove the antenna. Move the wire inbetween the two solder points so it is connecting to the second point. Once there take your soldering Iron and heat up the solder and drag it over the wire to make the connection.
    댓글 쓰기
    • Just remember to leave the gap here. Do not bend the antenna to make the points touch your self. The gap that runs through it is there by design and changing that has adverse effects on controller and WiFi . But its that easy. My PS4 now works fine with controller and WiFi . No need for further tear-down and extra parts. Put bottom on. GTGo
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 39명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
bdcallen69
회원 가입일: 12/01/15
1,239 평판
안내서 1개를 작성함
41가이드 댓글
My console was giving me the same problem aft lots of research i came across ur guide and today i fixed the wifi antenna and its working awesome Thanks alot
Muzaffar - 답글 공유
Me podrías compartir la guía?
JasonJam21 Dc - 답글 공유
Could you share the guide?
I've run into a similar problem (PS4 won't recognize controllers) but wifi works fine. Is it possible that bluetooth doesn't work but wifi does?
gustavo - 답글 공유
I replaced my antenna with a new one. But im still experiencing input lag. What else should I do?
angellom90 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 79
지난 30일: 430
전체 시간: 208,006
