주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Paper Jam
  1. Repairing Paper Jam, Drum Unit and Toner Cartridge: 1 단계, 이미지 1개 중 1개
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
    댓글 쓰기
  2. Repairing Paper Jam: 2 단계, 이미지 3개 중 1개 Repairing Paper Jam: 2 단계, 이미지 3개 중 2개 Repairing Paper Jam: 2 단계, 이미지 3개 중 3개
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
    댓글 쓰기
  3. Repairing Paper Jam, Repairing Paper Jam: 3 단계, 이미지 2개 중 1개 Repairing Paper Jam, Repairing Paper Jam: 3 단계, 이미지 2개 중 2개
    • DO NOT TOUCH the electrodes on the right inner wall of the printer. Touching these electrodes can cause electrical damage to the printer.
    댓글 쓰기
  4. Repairing Paper Jam, Paper Jam Type 1: 4 단계, 이미지 3개 중 1개 Repairing Paper Jam, Paper Jam Type 1: 4 단계, 이미지 3개 중 2개 Repairing Paper Jam, Paper Jam Type 1: 4 단계, 이미지 3개 중 3개
    • If jammed, paper will be visible after removing the drum unit. To clear paper jam, reach into printer and grab a corner of the paper.
    • Proceed to lift paper up and out of the printer.
    • Jammed paper may require an excess amount of force to be removed from printer.
    댓글 쓰기
  5. Repairing Paper Jam, Paper Jam Type 2: 5 단계, 이미지 2개 중 1개 Repairing Paper Jam, Paper Jam Type 2: 5 단계, 이미지 2개 중 2개
    • Grab onto the lift located on the paper tray near the bottom on the front of the printer.
    • Pull the paper tray completely out of the printer by pulling towards yourself.
    댓글 쓰기
  6. Repairing Paper Jam: 6 단계, 이미지 2개 중 1개 Repairing Paper Jam: 6 단계, 이미지 2개 중 2개
    • If jammed paper is visible, grab onto the paper and remove by pulling up and towards yourself.
    • Jammed paper may require a large amount of force to be removed from printer.
    댓글 쓰기
  7. Repairing Paper Jam, Paper Jam Type 3: 7 단계, 이미지 3개 중 1개 Repairing Paper Jam, Paper Jam Type 3: 7 단계, 이미지 3개 중 2개 Repairing Paper Jam, Paper Jam Type 3: 7 단계, 이미지 3개 중 3개
    • Located on the back of the printer, open up the cover by grabbing onto the tab and pulling down.
    댓글 쓰기
  8. Repairing Paper Jam: 8 단계, 이미지 3개 중 1개 Repairing Paper Jam: 8 단계, 이미지 3개 중 2개 Repairing Paper Jam: 8 단계, 이미지 3개 중 3개
    • In front of you will see two blue tabs, one on the left and right side.
    • First, push the top part of the tab in until the bottom part of the tab lifts up.
    • Grab onto the bottom part of the tab.
    댓글 쓰기
  9. Repairing Paper Jam: 9 단계, 이미지 2개 중 1개 Repairing Paper Jam: 9 단계, 이미지 2개 중 2개
    • Once you have a firm grib of both the right and left tab, lift both tabs up and towards yourself.
    • The fuser cover, which the tabs are connected to, does not come completely out of the printer because it is attached to the bottom by a hinge.
    댓글 쓰기
  10. Repairing Paper Jam: 10 단계, 이미지 3개 중 1개 Repairing Paper Jam: 10 단계, 이미지 3개 중 2개 Repairing Paper Jam: 10 단계, 이미지 3개 중 3개
    • If jammed paper is visible, grab onto the top of the paper and pull up until completely removed from printer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nathan Ruiz
회원 가입일: 01/14/10
186 평판
안내서 2개를 작성함
Cal Poly, Team 4-14, Forte Winter 2010 Cal Poly, Team 4-14, Forte Winter 2010 회원
CPSU-FORTE-W10S4G14
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 61
전체 시간: 15,246
