주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Puppet Strings
필요한 것
  1. Repairing Puppet Strings, Repairing Puppet Strings: 1 단계, 이미지 1개 중 1개
    • Detach the severed/damaged strings. This can be done by cutting them or carefully pulling them out.
    댓글 쓰기
  2. Repairing Puppet Strings: 2 단계, 이미지 1개 중 1개
    • Thread the fishing line through the needle as you would with thread and tie a simple knot to secure the fishing line.
    • Note: Tying the knot can be tedious, so it may take a few tries.
    댓글 쓰기
  3. Repairing Puppet Strings: 3 단계, 이미지 1개 중 1개
    • Insert the needle into a secure part of the puppet's feet or other necessary puppet part.
    • Note: The material may resist the needle at first.
    댓글 쓰기
  4. Repairing Puppet Strings: 4 단계, 이미지 2개 중 1개 Repairing Puppet Strings: 4 단계, 이미지 2개 중 2개
    • Pull the needle through the puppet part and tie another simple knot directly onto the location that was threaded through.
    • Note: You may want to tie a few simple knots for extra security.
    댓글 쓰기
  5. Repairing Puppet Strings: 5 단계, 이미지 1개 중 1개
    • If you need to make a handle, take the two wooden sticks and cross them to where they are perpendicular to each other.
    댓글 쓰기
  6. Repairing Puppet Strings: 6 단계, 이미지 1개 중 1개
    • Secure the two sticks with tape or glue where the two sticks cross.
    • Note: Tape is a faster fix, but may appear messier.
    댓글 쓰기
  7. Repairing Puppet Strings: 7 단계, 이미지 1개 중 1개
    • Tie a knot around the stick handle to secure the fishing line. (it may take several knots to secure the fishing line and you can adjust the length as needed with scissors)
    • Note: Repeat the previous steps to other parts of the puppet if necessary.
    댓글 쓰기
  8. Repairing Puppet Strings: 8 단계, 이미지 1개 중 1개
    • This is what your puppet should look like.
    • Happy puppet-ing!
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Stephanie Gummelt
회원 가입일: 10/27/15
155 평판
안내서 1개를 작성함
Missouri Western, Team 1-4, Adkins Fall 2015 Missouri Western, Team 1-4, Adkins Fall 2015 회원
MWSU-ADKINS-F15S1G4
2 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 51
전체 시간: 3,758
