주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Quasar Microwave Door Handle
필요한 것
    1. Repairing Quasar Microwave Door Handle, Disassembling Quasar Microwave Outer Cover: 1 단계, 이미지 1개 중 1개
      • Disconnect the power supply cord from the outlet.
      댓글 쓰기
    2. Repairing Quasar Microwave Door Handle: 2 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Door Handle: 2 단계, 이미지 2개 중 2개
      • Remove the eight screws holding the wood-patterned cover to the microwave frame.
      • The first four screws are located on either side of the microwave front.
      댓글 쓰기
    3. Repairing Quasar Microwave Door Handle: 3 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Door Handle: 3 단계, 이미지 2개 중 2개
      • Remove the additional four screws securing the wood-paneled case to the microwave frame.
      댓글 쓰기
    4. Repairing Quasar Microwave Door Handle: 4 단계, 이미지 3개 중 1개 Repairing Quasar Microwave Door Handle: 4 단계, 이미지 3개 중 2개 Repairing Quasar Microwave Door Handle: 4 단계, 이미지 3개 중 3개
      • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
      • Lift the case upward slowly until the case is free of the microwave.
      댓글 쓰기
    1. Repairing Quasar Microwave Door Handle, Repairing Quasar Microwave Door Handle: 5 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Door Handle, Repairing Quasar Microwave Door Handle: 5 단계, 이미지 2개 중 2개
      • Observe the lever mechanism found just behind the door handle, inside the microwave.
      • The plastic lever should be above the metal lever. If the metal lever is above the plastic lever, this is why the door will not open.
      • In this picture, the metal part is ABOVE the white plastic part. The white part needs to be lifted to open the door so when the door lever is pressed, the metal part rises, and the plastic part stays in place.
      댓글 쓰기
    2. Repairing Quasar Microwave Door Handle: 6 단계, 이미지 3개 중 1개 Repairing Quasar Microwave Door Handle: 6 단계, 이미지 3개 중 2개 Repairing Quasar Microwave Door Handle: 6 단계, 이미지 3개 중 3개
      • Lift up on the outside lever.
      • Push up on the white plastic piece.
      • Push metal bar down, snapping the white plastic piece above it.
      댓글 쓰기
    3. Repairing Quasar Microwave Door Handle: 7 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Door Handle: 7 단계, 이미지 2개 중 2개
      • This is how the fixed mechanism should look.
      • Press the button and enjoy your newly fixed door!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Samuel
회원 가입일: 09/26/12
142 평판
안내서 2개를 작성함
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G12
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 33
전체 시간: 2,695
