주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing VTech Touch and Swipe Baby Phone Screen Alignment
필요한 것
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: 1 단계, 이미지 2개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: 1 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
      댓글 쓰기
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 2 단계, 이미지 3개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 2 단계, 이미지 3개 중 2개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 2 단계, 이미지 3개 중 3개
      • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
      댓글 쓰기
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 3 단계, 이미지 3개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 3 단계, 이미지 3개 중 2개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 3 단계, 이미지 3개 중 3개
      • When reassembling, align the notch on the battery panel with the slot on the phone.
      댓글 쓰기
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 4 단계, 이미지 2개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 4 단계, 이미지 2개 중 2개
      • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
      댓글 쓰기
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 5 단계, 이미지 3개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 5 단계, 이미지 3개 중 2개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 5 단계, 이미지 3개 중 3개
      • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
      댓글 쓰기
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 6 단계, 이미지 2개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 6 단계, 이미지 2개 중 2개
      • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
      • Slide off the spring.
      댓글 쓰기
    4. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 7 단계, 이미지 3개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 7 단계, 이미지 3개 중 2개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 7 단계, 이미지 3개 중 3개
      • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
      • Lift up the black plastic piece.
      댓글 쓰기
    5. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 8 단계, 이미지 2개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 8 단계, 이미지 2개 중 2개
      • Remove four 7.5mm screws with a Phillips #0 screwdriver.
      댓글 쓰기
    6. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 9 단계, 이미지 2개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 9 단계, 이미지 2개 중 2개
      • Remove the two buttons, noting how wires are placed for reassembly.
      댓글 쓰기
    7. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 10 단계, 이미지 2개 중 1개 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 10 단계, 이미지 2개 중 2개
      • Lift the button board up and away to clear room for lifting the motherboard.
      • Tilt the assembly up but being wary that it is still attached to the front panel.
      댓글 쓰기
    8. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 11 단계, 이미지 1개 중 1개
      • Slide the toothed slider towards you to remove.
      댓글 쓰기
    9. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 12 단계, 이미지 1개 중 1개
      • To reassemble, align the two black lines together by moving the belt back and forth.
      • Once aligned reinsert the toothed slider at the exact point shown.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sean Webb
회원 가입일: 09/04/15
384 평판
안내서 2개를 작성함
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G4
3 회원들
안내서 12개를 작성함
1가이드 댓글
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 49
전체 시간: 1,943
