주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Vizio Television Cable Connection
필요한 것
  1. Repairing Vizio Television  Cable Connection, Repairing Vizio Television  Cable Connection: 1 단계, 이미지 1개 중 1개
    • First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
    • Don't forget the 2 Phillips screws in the motherboard area (circled in red).
    댓글 쓰기
  2. Repairing Vizio Television  Cable Connection: 2 단계, 이미지 3개 중 1개 Repairing Vizio Television  Cable Connection: 2 단계, 이미지 3개 중 2개 Repairing Vizio Television  Cable Connection: 2 단계, 이미지 3개 중 3개
    • After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
    • (2) Phillips screws hold down covers over your inputs.
    • Note this screw holds down both covers where they overlap.
    • The bottom cover will not move until the 2 small Phillips screws are removed.
    댓글 쓰기
  3. Repairing Vizio Television  Cable Connection: 3 단계, 이미지 2개 중 1개 Repairing Vizio Television  Cable Connection: 3 단계, 이미지 2개 중 2개
    • Once the covers are all removed, you'll see a big hole where the cable connection is supposed to be.
    • Proceed to solder your new connection in like I did here. If you decide to replace the entire part you'll need to remove the motherboard... We'll save that for a different thread.
    댓글 쓰기
  4. Repairing Vizio Television  Cable Connection: 4 단계, 이미지 1개 중 1개
    • You can then put it all back together once again in reverse order and enjoy some cable TV!
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Ricky
회원 가입일: 09/17/13
867 평판
안내서 3개를 작성함
TechTucson WeFixThat TechTucson WeFixThat 회원
Community
2 회원들
안내서 4개를 작성함
7가이드 댓글
Are there pics of what needs to be done in order to solder the cable connector correctly?
MistaRite145 - 답글 공유
how can I order the part to repair the coax connector for the Vizio 32 inch tv
Steven William Schwenn - 답글 공유
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
john kowalski - 답글 공유
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
jpfernandez211 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 84
전체 시간: 18,800
