주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Zipper Slider
필요한 것
    1. Repairing Zipper Slider, Identifying a Bad Zipper Slider: 1 단계, 이미지 2개 중 1개 Repairing Zipper Slider, Identifying a Bad Zipper Slider: 1 단계, 이미지 2개 중 2개
      • A zipper that separates behind the zipper slider like the one shown on this tent is a very common zipper failure mode on backpacks and luggage too. It's an easy fix with a locking pliers: the goal is to carefully squeeze the top and bottom plates of the zipper slider just ever so slightly closer.
      댓글 쓰기
    2. Repairing Zipper Slider, Positioning Locking Pliers to Repair a Zipper: 2 단계, 이미지 2개 중 1개 Repairing Zipper Slider, Positioning Locking Pliers to Repair a Zipper: 2 단계, 이미지 2개 중 2개
      • With the locking pliers in the locked position: use the screw adjustment at the back to close on the zipper slider. (Make sure you're clamping just the zipper slider and NOT the zipper pulls or fabric.)
      • Remove the locking pliers and tighten the screw adjustment ever so slightly: a 1/16th or 1/8th of a turn should be enough: you're trying to apply the slightest pressure to both sides of the zipper slider when you re-apply it.
      • Return the locking pliers to the proper position on the zipper slider and clamp the locking mechanism down: this time, the locking pliers should lock just a little as you clamp down. Clamp the zipper slider on BOTH sides with the same setting before changing anything.
      • It might take a few tries with successively tighter settings on the locking pliers but eventually the zipper will start zipping properly again.
      댓글 쓰기
    3. Repairing Zipper Slider, Miscellaneous Zipper Slider Tips: 3 단계, 이미지 1개 중 1개
      • This technique even works with pitched tents, which is typically when you figure out that the zipper needs fixing. It works on luggage, backpacks, any zipper that has a metal slider.
      • If you overdo it with the locking pliers the zipper might get hard to zip. You can open the gaps on both sides in the zipper slider a little with a thin flat blade screwdriver, but it's best to work slowly and avoid that scenario.
      • Don't have locking pliers or vise grip? You can use a regular pliers in a pinch, as this person did with their backpack.
      • Someone took a video of me using this technique to repair a backpack: https://youtu.be/BhehrLek2XM
      댓글 쓰기
결론
Congratulate yourself on having saved yourself from replacing an expensive fabric item (or at least a zipper.)
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Fixit Clinic
회원 가입일: 01/13/15
786 평판
안내서 2개를 작성함
2가이드 댓글
Sometimes the metal in the zip will have become weakened and this method will not work. If this happens try using Zlideon zips. https://zlideon.com/ They are quite expensive but worth the money if the item is expensive or much loved. (Note I am not in any way connected to Zlideon but I have used their zipper replacements several times).
SussexDab - 답글 공유
Literally took two seconds to fix a zipper. THANK YOU
Emma Hochstetler - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 63
지난 30일: 294
전체 시간: 28,034
