주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Replacing Creative Zen X-Fi Battery
필요한 것
    1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: 1 단계, 이미지 3개 중 1개 Replacing Creative Zen X-Fi Battery, Detaching Front Case: 1 단계, 이미지 3개 중 2개 Replacing Creative Zen X-Fi Battery, Detaching Front Case: 1 단계, 이미지 3개 중 3개
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      댓글 쓰기
    1. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: 2 단계, 이미지 1개 중 1개
      • The black rubber button pad can be removed by simply picking it up.
      댓글 쓰기
    1. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: 3 단계, 이미지 1개 중 1개
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      댓글 쓰기
    2. Replacing Creative Zen X-Fi Battery, Button Input Chip: 4 단계, 이미지 1개 중 1개
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      댓글 쓰기
    1. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: 5 단계, 이미지 1개 중 1개
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      댓글 쓰기
    2. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: 6 단계, 이미지 1개 중 1개
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      댓글 쓰기
    3. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: 7 단계, 이미지 1개 중 1개
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      댓글 쓰기
    1. Replacing Creative Zen X-Fi Battery, Separating the Battery: 8 단계, 이미지 1개 중 1개
      • Use a spudger to pry the battery from the midsection plate.
      • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
      댓글 쓰기
    2. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: 9 단계, 이미지 2개 중 1개 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: 9 단계, 이미지 2개 중 2개
      • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
      • Hold the battery wires in place so that access to the soldering joints is not blocked.
      • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
      • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
2가이드 댓글
very clear pictures!
John - 답글 공유
разбирать нужно со стороны противоположной гнезда наушников!!! поломал так же как и на фото все защелки со стороны кнопок(
Cooper21 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 95
전체 시간: 8,824
