주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Replacing Creative Zen X-Fi Speaker
필요한 것
    1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: 1 단계, 이미지 3개 중 1개 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: 1 단계, 이미지 3개 중 2개 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: 1 단계, 이미지 3개 중 3개
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      댓글 쓰기
    1. Replacing Creative Zen X-Fi Speaker, Rubber Button Cover: 2 단계, 이미지 1개 중 1개
      • The black rubber button pad can be removed by simply picking it up.
      댓글 쓰기
    1. Replacing Creative Zen X-Fi Speaker, Button Input Chip Part 1: 3 단계, 이미지 1개 중 1개
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      댓글 쓰기
    2. Replacing Creative Zen X-Fi Speaker, Button Input Chip: 4 단계, 이미지 1개 중 1개
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      댓글 쓰기
    1. Replacing Creative Zen X-Fi Speaker, Access Midsection Plate: 5 단계, 이미지 1개 중 1개
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      댓글 쓰기
    2. Replacing Creative Zen X-Fi Speaker, Unscrew below Button Chip: 6 단계, 이미지 1개 중 1개
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      댓글 쓰기
    3. Replacing Creative Zen X-Fi Speaker, Unscrew below LCD Screen: 7 단계, 이미지 1개 중 1개
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      댓글 쓰기
    1. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: 8 단계, 이미지 2개 중 1개 Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: 8 단계, 이미지 2개 중 2개
      • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
      • Once unscrewed, pick up the case and put it to the side.
      댓글 쓰기
    2. Replacing Creative Zen X-Fi Speaker, Removing the Speaker: 9 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 47
전체 시간: 755
