주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Replacing Tungsten E screen. PAL5037
필요한 것
    1. Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: 1 단계, 이미지 2개 중 1개 Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: 1 단계, 이미지 2개 중 2개
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
      댓글 쓰기
    2. Replacing Tungsten E screen. PAL5037: 2 단계, 이미지 3개 중 1개 Replacing Tungsten E screen. PAL5037: 2 단계, 이미지 3개 중 2개 Replacing Tungsten E screen. PAL5037: 2 단계, 이미지 3개 중 3개
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
      댓글 쓰기
    3. Replacing Tungsten E screen. PAL5037: 3 단계, 이미지 2개 중 1개 Replacing Tungsten E screen. PAL5037: 3 단계, 이미지 2개 중 2개
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
      댓글 쓰기
    4. Replacing Tungsten E screen. PAL5037: 4 단계, 이미지 2개 중 1개 Replacing Tungsten E screen. PAL5037: 4 단계, 이미지 2개 중 2개
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
      댓글 쓰기
    5. Replacing Tungsten E screen. PAL5037: 5 단계, 이미지 3개 중 1개 Replacing Tungsten E screen. PAL5037: 5 단계, 이미지 3개 중 2개 Replacing Tungsten E screen. PAL5037: 5 단계, 이미지 3개 중 3개
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
      댓글 쓰기
    6. Replacing Tungsten E screen. PAL5037: 6 단계, 이미지 1개 중 1개
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
      댓글 쓰기
    1. Replacing Tungsten E screen. PAL5037, Replacing Touch screen: 7 단계, 이미지 1개 중 1개
      • Reassemble the device in the reverse order of the tear down using the new screen in place of the old screen.
      • To reconnect the flex connector press up on the blocks with the spudger to ensure they click into place.
      • Be careful not to damage the flex connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Kevin Hom
회원 가입일: 01/21/10
118 평판
안내서 2개를 작성함
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 회원
CPSU-MANESS-W10S13G22
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 26
전체 시간: 5,943
