주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ResMed AirSense 10 Heater Fuse Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
    1. ResMed AirSense 10  Heater Fuse Replacement, Heater Plate Fuse: 1 단계, 이미지 2개 중 1개 ResMed AirSense 10  Heater Fuse Replacement, Heater Plate Fuse: 1 단계, 이미지 2개 중 2개
      • With medium pressure, place your thumb on the top of the tank and four fingers on the bottom.
      • Pull straight out on the tank until it releases from the device.
      댓글 쓰기
    2. ResMed AirSense 10  Heater Fuse Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four 10mm screws from the bottom of the device with a Torx T10 screwdriver.
      댓글 쓰기
    3. ResMed AirSense 10  Heater Fuse Replacement: 3 단계, 이미지 3개 중 1개 ResMed AirSense 10  Heater Fuse Replacement: 3 단계, 이미지 3개 중 2개 ResMed AirSense 10  Heater Fuse Replacement: 3 단계, 이미지 3개 중 3개
      • After the plastic cover has been removed you will be able to see the back of the heater plate. We will remove it from the device to making it easier to remove the fuse.
      • Pinching the three red cords, pull straight back on the heater plate power cord until it is removed from the connector.
      • After the cord has been removed from the connector, it will need to be pulled through the rubber grommet.
      • Gently pull the wires to the connector until the white connector is touching the rubber grommet.
      • Using light force, push the white connector on the end of the heater plate power cords through the rubber grommet.
      댓글 쓰기
    4. ResMed AirSense 10  Heater Fuse Replacement: 4 단계, 이미지 3개 중 1개 ResMed AirSense 10  Heater Fuse Replacement: 4 단계, 이미지 3개 중 2개 ResMed AirSense 10  Heater Fuse Replacement: 4 단계, 이미지 3개 중 3개
      • Using the straight tipped tweezers, push the fuse away from fuse housing until the main body of the fuse is visible.
      • Take the straight tipped tweezers, grip the body of the fuse, and pull it free from the housing.
      • Make sure to not bend the wire of the fuse. Using the holes of the housing as a guide will allow you to put the fuse back in the correct orientation.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 22명이 해당 안내서를 완성하였습니다.
39가이드 댓글
Where can I buy a new fuse? This one does not look like one I can get at a hardware store.
pnreinhard - 답글 공유
Yws, please, where can we buy a new fuse? Thanks.
mustdeliver - 답글 공유
and yes where do you buy a fuse can’t find no where PLEASE @ cityboi53@yahoo.com
citycountryboi53 - 답글 공유
Did you get a reply as to where you can buy the fuse?
Wally Petrey - 답글 공유
any idea how can i get the fuse what are the specs and where can i buy one or someone know where to get the whole heating plate
andres usma - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 97
지난 30일: 400
전체 시간: 47,195
