주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Resetting the Palm m105
필요한 것
    1. Resetting the Palm m105, Device Reset: 1 단계, 이미지 1개 중 1개
      • To soft reset the device, use a paperclip to carefully press the reset button located on the back of the device. The exact location of the button can be seen in the picture.
      • A soft reset means that it will usually not affect your personal data on your device, unless the batteries are low.
      • After you press the button, the device will reboot as if you just powered on your device and it should clear up most common device problems.
      • If your device is still not powering up or has a blank display, the next step will help you perform a hard reset of the device.
      댓글 쓰기
    2. Resetting the Palm m105: 2 단계, 이미지 2개 중 1개 Resetting the Palm m105: 2 단계, 이미지 2개 중 2개
      • A hard reset will erase all current data on the device. This should only be done if a soft reset has not solved your problem.
      • A hard reset is done by simultaneously holding down the power button while also pressing the reset button on the back with a paper clip like you did for the soft reset. After a few seconds the Palm logo should appear, when it does, release the power button.
      • If applicable, you can restore any data previously synchronized with your PC through the HotSync operation of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
Erik Thompson
회원 가입일: 10/04/11
31 평판
안내서 5개를 작성함
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G3
4 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 37
전체 시간: 1,973
