주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Retro-Bit Retro Duo Circuit Board Replacement
필요한 것
  1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 3개
    • With the console on its top, remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
    • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
    댓글 쓰기
  2. Retro-Bit Retro Duo Circuit Board Replacement: 2 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Circuit Board Replacement: 2 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Circuit Board Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the one 6 mm Phillips #0 LED circuit board screw.
    • Lift the top case and set aside.
    댓글 쓰기
  3. Retro-Bit Retro Duo Circuit Board Replacement: 3 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Circuit Board Replacement: 3 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Circuit Board Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the 11 screws holding the circuit boards and ports in place.
    • Six 11 mm Phillips #2 holding the circuit boards.
    • Three 12 mm Phillips #2 screws holding the controller ports.
    • Two 7 mm Philllips #2 screws holding the back ports
    댓글 쓰기
  4. Retro-Bit Retro Duo Circuit Board Replacement: 4 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Circuit Board Replacement: 4 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Circuit Board Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
    • Make sure to lift the circuit board completely out of the bottom case.
    • To avoid damage, do not to touch the top or bottom faces of the circuit board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Truong Vo
회원 가입일: 09/25/17
324 평판
안내서 3개를 작성함
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G4
3 회원들
안내서 10개를 작성함
1가이드 댓글
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 51
전체 시간: 3,219
