주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Retroid Pocket 3 Button Pad Replacement
필요한 것
  1. Retroid Pocket 3 Button Pad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    댓글 쓰기
  2. Retroid Pocket 3 Button Pad Replacement: 2 단계, 이미지 3개 중 1개 Retroid Pocket 3 Button Pad Replacement: 2 단계, 이미지 3개 중 2개 Retroid Pocket 3 Button Pad Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    댓글 쓰기
  3. Retroid Pocket 3 Button Pad Replacement: 3 단계, 이미지 2개 중 1개 Retroid Pocket 3 Button Pad Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    댓글 쓰기
  4. Retroid Pocket 3 Button Pad Replacement: 4 단계, 이미지 3개 중 1개 Retroid Pocket 3 Button Pad Replacement: 4 단계, 이미지 3개 중 2개 Retroid Pocket 3 Button Pad Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    댓글 쓰기
  5. Retroid Pocket 3 Button Pad Replacement, Button Pad: 5 단계, 이미지 3개 중 1개 Retroid Pocket 3 Button Pad Replacement, Button Pad: 5 단계, 이미지 3개 중 2개 Retroid Pocket 3 Button Pad Replacement, Button Pad: 5 단계, 이미지 3개 중 3개
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
    댓글 쓰기
  6. Retroid Pocket 3 Button Pad Replacement: 6 단계, 이미지 2개 중 1개 Retroid Pocket 3 Button Pad Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    • Carefully lift the board out of the device.
    댓글 쓰기
  7. Retroid Pocket 3 Button Pad Replacement: 7 단계, 이미지 2개 중 1개 Retroid Pocket 3 Button Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
    댓글 쓰기
  8. Retroid Pocket 3 Button Pad Replacement: 8 단계, 이미지 1개 중 1개
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
    댓글 쓰기
  9. Retroid Pocket 3 Button Pad Replacement: 9 단계, 이미지 3개 중 1개 Retroid Pocket 3 Button Pad Replacement: 9 단계, 이미지 3개 중 2개 Retroid Pocket 3 Button Pad Replacement: 9 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
    댓글 쓰기
  10. Retroid Pocket 3 Button Pad Replacement: 10 단계, 이미지 3개 중 1개 Retroid Pocket 3 Button Pad Replacement: 10 단계, 이미지 3개 중 2개 Retroid Pocket 3 Button Pad Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully pry up the silicone button pad with a Spudger tool.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Cassidy Anderson
회원 가입일: 02/08/24
271 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 61
전체 시간: 1,240
