주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Retroid Pocket 3 LCD Screen Replacement
필요한 것
  1. Retroid Pocket 3 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    댓글 쓰기
  2. Retroid Pocket 3 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    댓글 쓰기
  3. Retroid Pocket 3 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    댓글 쓰기
  4. Retroid Pocket 3 LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    댓글 쓰기
  5. Retroid Pocket 3 LCD Screen Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
    댓글 쓰기
  6. Retroid Pocket 3 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
    댓글 쓰기
  7. Retroid Pocket 3 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Unclip and remove the one ribbon cable on the left.
    댓글 쓰기
  8. Retroid Pocket 3 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    댓글 쓰기
  9. Retroid Pocket 3 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
    댓글 쓰기
  10. Retroid Pocket 3 LCD Screen Replacement: 10 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 10 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
    댓글 쓰기
  11. Retroid Pocket 3 LCD Screen Replacement, Button Pad: 11 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement, Button Pad: 11 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement, Button Pad: 11 단계, 이미지 3개 중 3개
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
    댓글 쓰기
  12. Retroid Pocket 3 LCD Screen Replacement: 12 단계, 이미지 2개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    댓글 쓰기
  13. Retroid Pocket 3 LCD Screen Replacement: 13 단계, 이미지 2개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
    댓글 쓰기
  14. Retroid Pocket 3 LCD Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
    댓글 쓰기
  15. Retroid Pocket 3 LCD Screen Replacement: 15 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 15 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement: 15 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
    댓글 쓰기
  16. Retroid Pocket 3 LCD Screen Replacement: 16 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 16 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement: 16 단계, 이미지 3개 중 3개
    • Carefully pry up the silicone button pad with a Spudger tool.
    댓글 쓰기
  17. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: 17 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: 17 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: 17 단계, 이미지 3개 중 3개
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    댓글 쓰기
  18. Retroid Pocket 3 LCD Screen Replacement: 18 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 18 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement: 18 단계, 이미지 3개 중 3개
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    댓글 쓰기
  19. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: 19 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: 19 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: 19 단계, 이미지 3개 중 3개
    • Using the Spudger tool, remove the two speakers at the bottom of the device by gently prying them out.
    • Speakers are held by double-sided tape.
    댓글 쓰기
  20. Retroid Pocket 3 LCD Screen Replacement: 20 단계, 이미지 3개 중 1개 Retroid Pocket 3 LCD Screen Replacement: 20 단계, 이미지 3개 중 2개 Retroid Pocket 3 LCD Screen Replacement: 20 단계, 이미지 3개 중 3개
    • Remove the joysticks by unscrewing the two 3.5mm screws with a Phillips #00 screwdriver.
    • Remove the metal backplate from the front casing of the device by unscrewing the ten 3.5mm screws using the Phillips #00 screwdriver.
    • Carefully lift the ribbon cable from the metal backplate
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Troy
회원 가입일: 02/08/24
85 평판
안내서 1개를 작성함
1가이드 댓글
Hello. Can you tell where I can find a new replacement screen?
Aliaksandr - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 110
전체 시간: 2,456
