주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Retroid Pocket 3 Motherboard Replacement
필요한 것
  1. Retroid Pocket 3 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    댓글 쓰기
  2. Retroid Pocket 3 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Retroid Pocket 3 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Retroid Pocket 3 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    댓글 쓰기
  3. Retroid Pocket 3 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Retroid Pocket 3 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    댓글 쓰기
  4. Retroid Pocket 3 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Retroid Pocket 3 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Retroid Pocket 3 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    댓글 쓰기
  5. Retroid Pocket 3 Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
    댓글 쓰기
  6. Retroid Pocket 3 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
    댓글 쓰기
  7. Retroid Pocket 3 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Unclip and remove the one ribbon cable on the left.
    댓글 쓰기
  8. Retroid Pocket 3 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    댓글 쓰기
  9. Retroid Pocket 3 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Retroid Pocket 3 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
    댓글 쓰기
  10. Retroid Pocket 3 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Retroid Pocket 3 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Retroid Pocket 3 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Willem Pretorius
회원 가입일: 02/08/24
198 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 52
전체 시간: 1,483
