주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Retroid Pocket 3 Trigger Button Replacement
필요한 것
  1. Retroid Pocket 3 Trigger Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    댓글 쓰기
  2. Retroid Pocket 3 Trigger Button Replacement: 2 단계, 이미지 3개 중 1개 Retroid Pocket 3 Trigger Button Replacement: 2 단계, 이미지 3개 중 2개 Retroid Pocket 3 Trigger Button Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    댓글 쓰기
  3. Retroid Pocket 3 Trigger Button Replacement: 3 단계, 이미지 2개 중 1개 Retroid Pocket 3 Trigger Button Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    댓글 쓰기
  4. Retroid Pocket 3 Trigger Button Replacement: 4 단계, 이미지 3개 중 1개 Retroid Pocket 3 Trigger Button Replacement: 4 단계, 이미지 3개 중 2개 Retroid Pocket 3 Trigger Button Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    댓글 쓰기
  5. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: 5 단계, 이미지 3개 중 1개 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: 5 단계, 이미지 3개 중 2개 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: 5 단계, 이미지 3개 중 3개
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    댓글 쓰기
  6. Retroid Pocket 3 Trigger Button Replacement: 6 단계, 이미지 3개 중 1개 Retroid Pocket 3 Trigger Button Replacement: 6 단계, 이미지 3개 중 2개 Retroid Pocket 3 Trigger Button Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Max Briseno
회원 가입일: 02/08/24
88 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 25
지난 30일: 91
전체 시간: 1,600
