주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Retroid Pocket Flip D-Pad Replacement
필요한 것
  1. Retroid Pocket Flip D-Pad Replacement, Back Plate Assembly: 1 단계, 이미지 2개 중 1개 Retroid Pocket Flip D-Pad Replacement, Back Plate Assembly: 1 단계, 이미지 2개 중 2개
    • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
    • Use a plastic opening pick to carefully separate the back cover from the device.
    댓글 쓰기
  2. Retroid Pocket Flip D-Pad Replacement: 2 단계, 이미지 2개 중 1개 Retroid Pocket Flip D-Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic spudger to carefully lift and disconnect the battery connector.
    • Use tweezers to disconnect the connector from its socket.
    댓글 쓰기
  3. Retroid Pocket Flip D-Pad Replacement, Joystick: 3 단계, 이미지 2개 중 1개 Retroid Pocket Flip D-Pad Replacement, Joystick: 3 단계, 이미지 2개 중 2개
    • Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
    • Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
    • Use tweezers to remove the "R" sticker to reveal the last screw.
    댓글 쓰기
  4. Retroid Pocket Flip D-Pad Replacement: 4 단계, 이미지 3개 중 1개 Retroid Pocket Flip D-Pad Replacement: 4 단계, 이미지 3개 중 2개 Retroid Pocket Flip D-Pad Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully lift and unstick the fan module using a plastic spudger, then remove it.
    • Remove the sticky ribbon connectors on each side of the plate with a plastic spudger.
    • Use a plastic spudger to carefully separate the shield from the board.
    • Do not pull abruptly: the shield is partially bonded to the CPU with thermal paste. You can use a hair dryer on low heat to soften the paste slightly before lifting the shield.
    댓글 쓰기
  5. Retroid Pocket Flip D-Pad Replacement: 5 단계, 이미지 3개 중 1개 Retroid Pocket Flip D-Pad Replacement: 5 단계, 이미지 3개 중 2개 Retroid Pocket Flip D-Pad Replacement: 5 단계, 이미지 3개 중 3개
    • Use tweezers to unclip and remove the two ribbon cables on each joystick module.
    • Use a plastic spudger to lift and remove the joystick modules; they are secured with double sided tape.
    댓글 쓰기
  6. Retroid Pocket Flip D-Pad Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 Retroid Pocket Flip D-Pad Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 Retroid Pocket Flip D-Pad Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
    • Use tweezers to disconnect the ribbon cables from the board.
    • Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
    • Always lift the coaxial connector straight up. Do not pry at an angle, as this can detach the socket from the motherboard.
    댓글 쓰기
  7. Retroid Pocket Flip D-Pad Replacement: 7 단계, 이미지 2개 중 1개 Retroid Pocket Flip D-Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the six 5.8 mm screws from the motherboard using a JIS #00 screwdriver.
    • Carefully lift the motherboard out of the device.
    댓글 쓰기
  8. Retroid Pocket Flip D-Pad Replacement, D-Pad: 8 단계, 이미지 3개 중 1개 Retroid Pocket Flip D-Pad Replacement, D-Pad: 8 단계, 이미지 3개 중 2개 Retroid Pocket Flip D-Pad Replacement, D-Pad: 8 단계, 이미지 3개 중 3개
    • Remove the rubber piece backing the D-pad out of the device.
    • Lift the D-pad out of the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Chania Gonzalez Alves
회원 가입일: 01/16/26
145 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 35
전체 시간: 115
