주요 콘텐츠로 건너뛰기
Rexing V1P Plus Front Camera Replacement
필요한 것
  1. Rexing V1P Plus Front Camera Replacement, Front Camera: 1 단계, 이미지 3개 중 1개 Rexing V1P Plus Front Camera Replacement, Front Camera: 1 단계, 이미지 3개 중 2개 Rexing V1P Plus Front Camera Replacement, Front Camera: 1 단계, 이미지 3개 중 3개
    • Begin by orienting the device with the LCD screen facing down.
    • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
  2. Rexing V1P Plus Front Camera Replacement: 2 단계, 이미지 3개 중 1개 Rexing V1P Plus Front Camera Replacement: 2 단계, 이미지 3개 중 2개 Rexing V1P Plus Front Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the back cover of the device and place it to the side.
    • Rotate the device 180 degrees to where the camera is facing you.
  3. Rexing V1P Plus Front Camera Replacement: 3 단계, 이미지 3개 중 1개 Rexing V1P Plus Front Camera Replacement: 3 단계, 이미지 3개 중 2개 Rexing V1P Plus Front Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
  4. Rexing V1P Plus Front Camera Replacement: 4 단계, 이미지 3개 중 1개 Rexing V1P Plus Front Camera Replacement: 4 단계, 이미지 3개 중 2개 Rexing V1P Plus Front Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
  5. Rexing V1P Plus Front Camera Replacement: 5 단계, 이미지 3개 중 1개 Rexing V1P Plus Front Camera Replacement: 5 단계, 이미지 3개 중 2개 Rexing V1P Plus Front Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
  6. Rexing V1P Plus Front Camera Replacement: 6 단계, 이미지 3개 중 1개 Rexing V1P Plus Front Camera Replacement: 6 단계, 이미지 3개 중 2개 Rexing V1P Plus Front Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
    • It will rest loosely around the white camera ribbon.
    • Rotate the device 180 degrees to where the camera is facing away from you.
  7. Rexing V1P Plus Front Camera Replacement: 7 단계, 이미지 3개 중 1개 Rexing V1P Plus Front Camera Replacement: 7 단계, 이미지 3개 중 2개 Rexing V1P Plus Front Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully peel back the adhesive material covering the ribbon cable connection.
  8. Rexing V1P Plus Front Camera Replacement: 8 단계, 이미지 3개 중 1개 Rexing V1P Plus Front Camera Replacement: 8 단계, 이미지 3개 중 2개 Rexing V1P Plus Front Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
    • Once the connector is open, slide the ribbon cable out to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ryan Horne
회원 가입일: 02/14/23
270 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 224
