주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ricoh Shotmaster 130Z Shutter LED Replacement
필요한 것
    1. Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: 1 단계, 이미지 3개 중 1개 Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: 1 단계, 이미지 3개 중 2개 Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: 1 단계, 이미지 3개 중 3개
      • Using a Phillips J00 head remove the three 5mm screws on both left and right side of the camera as well as the one in back of it.
      댓글 쓰기
    2. Ricoh Shotmaster 130Z Shutter LED  Replacement: 2 단계, 이미지 1개 중 1개
      • Using the same J00 phillips head screwdriver proceed to removing the remaining four 5mm screws on the bottom of the camera.
      • Last, using the same #00 phillips head screwdriver remove the two 0.6mm screws which are one on each side of the tripod connection dip.
      댓글 쓰기
    3. Ricoh Shotmaster 130Z Shutter LED  Replacement: 3 단계, 이미지 2개 중 1개 Ricoh Shotmaster 130Z Shutter LED  Replacement: 3 단계, 이미지 2개 중 2개
      • The case can now be removed from the camera.
      • Using a blue opening tool start by lifting the back part of the case right where the tripod dip is. Lift until the back part of the case is released and can be easily removed
      • Next, using the same opening tool lift and push by the battery compartment as shown in the second picture. Do this until the front part of the case is released and can be easily removed.
      댓글 쓰기
    4. Ricoh Shotmaster 130Z Shutter LED  Replacement: 4 단계, 이미지 2개 중 1개 Ricoh Shotmaster 130Z Shutter LED  Replacement: 4 단계, 이미지 2개 중 2개
      • The LED diode to be replaced can be found in the front of the camera next to the zooming lens.
      • Desolder the LED to remove it from the motherboard
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
anna carolina von einem
회원 가입일: 10/19/16
450 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 UMass Dartmouth, Team 3-4, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G4
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 26
전체 시간: 549
