주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ring Outdoor Security Cam Infrared Sensor Replacement
필요한 것
  1. Ring Outdoor Security Cam Infrared Sensor Replacement, Infrared Sensor: 1 단계, 이미지 1개 중 1개
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
    댓글 쓰기
  2. Ring Outdoor Security Cam Infrared Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • Pry off the aluminum plate using a plastic opening tool.
    댓글 쓰기
  3. Ring Outdoor Security Cam Infrared Sensor Replacement: 3 단계, 이미지 1개 중 1개
    • Using the same tool pry the back plate off of the device.
    댓글 쓰기
  4. Ring Outdoor Security Cam Infrared Sensor Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery power leads using a plastic opening tool.
    댓글 쓰기
  5. Ring Outdoor Security Cam Infrared Sensor Replacement: 5 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    댓글 쓰기
  6. Ring Outdoor Security Cam Infrared Sensor Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
    댓글 쓰기
  7. Ring Outdoor Security Cam Infrared Sensor Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the top of the motherboard up and out of the device.
    댓글 쓰기
  8. Ring Outdoor Security Cam Infrared Sensor Replacement: 8 단계, 이미지 2개 중 1개 Ring Outdoor Security Cam Infrared Sensor Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Remove the 3 plastic spacers on the device.
    댓글 쓰기
  9. Ring Outdoor Security Cam Infrared Sensor Replacement: 9 단계, 이미지 3개 중 1개 Ring Outdoor Security Cam Infrared Sensor Replacement: 9 단계, 이미지 3개 중 2개 Ring Outdoor Security Cam Infrared Sensor Replacement: 9 단계, 이미지 3개 중 3개
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
    댓글 쓰기
  10. Ring Outdoor Security Cam Infrared Sensor Replacement: 10 단계, 이미지 1개 중 1개
    • Using a soldering iron to disconnect the connections.
    • Remove the infrared sensor and replace as needed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
WilliamB22
회원 가입일: 09/13/23
968 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 27
전체 시간: 583
