주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ring Stick Up Cam Battery Camera Replacement
필요한 것
    1. Ring Stick Up Cam Battery Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Turn the camera so the lens is facing away from you, and the back is facing towards you.
      • Place one hand securely on the base and the other on the stand.
      • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
      댓글 쓰기
    2. Ring Stick Up Cam Battery Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Gently pull down to separate the stand from the camera body.
      댓글 쓰기
    3. Ring Stick Up Cam Battery Camera Replacement: 3 단계, 이미지 2개 중 1개 Ring Stick Up Cam Battery Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Hold the camera so the opening containing the battery is toward the ceiling.
      • Squeeze the silver lever labeled "push" and extract the battery from its slot.
      댓글 쓰기
    1. Ring Stick Up Cam Battery Camera Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Halberd Spudger
      $2.99
      • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
      댓글 쓰기
    2. Ring Stick Up Cam Battery Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
      댓글 쓰기
    3. Ring Stick Up Cam Battery Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Rotate the device so the base is facing upward.
      • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
      • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
      댓글 쓰기
    4. Ring Stick Up Cam Battery Camera Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the silver latch from the base.
      • Remove the front cover.
      • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
      • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
      댓글 쓰기
    5. Ring Stick Up Cam Battery Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Pry the inside panel open using your hands or a spudger if necessary.
      댓글 쓰기
    6. Ring Stick Up Cam Battery Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
      댓글 쓰기
    7. Ring Stick Up Cam Battery Camera Replacement: 10 단계, 이미지 2개 중 1개 Ring Stick Up Cam Battery Camera Replacement: 10 단계, 이미지 2개 중 2개
      • Lift the motherboard from the camera body with the halberd spudger.
      댓글 쓰기
    8. Ring Stick Up Cam Battery Camera Replacement: 11 단계, 이미지 2개 중 1개 Ring Stick Up Cam Battery Camera Replacement: 11 단계, 이미지 2개 중 2개
      • Rotate the device to its side.
      • With your fingers, carefully remove the white part of the cord clip from the beige base.
      • Repeat this for the remaining three cords connecting the motherboard to the camera body.
      댓글 쓰기
    9. Ring Stick Up Cam Battery Camera Replacement: 12 단계, 이미지 1개 중 1개
      • Fold the motherboard downward from the camera body, revealing a white connecting strip.
      • Using the flat end of a spudger, flick the black hinge upward.
      • Pull the white strip out of the slot.
      댓글 쓰기
    10. Ring Stick Up Cam Battery Camera Replacement: 13 단계, 이미지 2개 중 1개 Ring Stick Up Cam Battery Camera Replacement: 13 단계, 이미지 2개 중 2개
      • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
      • Gently remove the adhesive cover from the motherboard.
      댓글 쓰기
    1. Ring Stick Up Cam Battery Camera Replacement, Camera: 14 단계, 이미지 1개 중 1개
      • Orient your device so that the interior of the camera body is facing the ceiling.
      댓글 쓰기
    2. Ring Stick Up Cam Battery Camera Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the two 6 mm screws that connect the camera to the camera body using a Phillips #00 screwdriver.
      댓글 쓰기
    3. Ring Stick Up Cam Battery Camera Replacement: 16 단계, 이미지 1개 중 1개
      • Grab and twist the camera counterclockwise with your thumb and index finger.
      댓글 쓰기
    4. Ring Stick Up Cam Battery Camera Replacement: 17 단계, 이미지 2개 중 1개 Ring Stick Up Cam Battery Camera Replacement: 17 단계, 이미지 2개 중 2개
      • Using your fingers, lift out the camera component including the camera lens and the attached wire.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nick Tomkins
회원 가입일: 02/24/23
124 평판
안내서 1개를 작성함
Marist, Team 1-1, Chaterdon Spring 2023 Marist, Team 1-1, Chaterdon Spring 2023 회원
MARS-CHATERDON-S23S1G1
3 회원들
안내서 8개를 작성함
1가이드 댓글
Seriously where do you get the part
Tonio Lopez (Tony) - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 105
전체 시간: 7,631
