주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ring Stick Up Cam Battery Replacement
필요한 것
    1. Ring Stick Up Cam Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Remove the six 6mm Phillips #00 screws from the back of the device.
      댓글 쓰기
    2. Ring Stick Up Cam Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Pry off the aluminum plate using a plastic opening tool.
      댓글 쓰기
    3. Ring Stick Up Cam Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
      댓글 쓰기
    4. Ring Stick Up Cam Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Pry off the back cover using a plastic opening tool.
      댓글 쓰기
    5. Ring Stick Up Cam Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Disconnect the battery power leads using a plastic opening tool.
      댓글 쓰기
    6. Ring Stick Up Cam Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nicholos Frey
회원 가입일: 02/05/19
424 평판
안내서 1개를 작성함
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019 회원
UCD-LORE-W19S18G3
3 회원들
안내서 8개를 작성함
12가이드 댓글
Where can I get a replacement battery?
jbains - 답글 공유
Bad news,
After three different calls to the Ring customer service line (just to be certain i was getting the true honest answer each time) i was told that the Ring stickup 1st generation cam - the one in this section is not available and never was. They suggest that this model was never intended yo be dissected as easy as we know it is. the best we can do is to find someone selling one with a damaged camera and removing its battery. That was how i was able to get my 1st gen stickup back in service again.
Dave S - 답글 공유
No reason to try this, no battery replacement? Have searched the Internet, can’t find a replacement!
Robert Byrum - 답글 공유
Why would they not use the same simple replaceable battery system as the ring doorbell2
Peter Lasnick - 답글 공유
Would love to replace the battery, if I could find it online…
Matthew Grow - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 48
전체 시간: 13,907
